Results 16 to 30 of 83
04-01-2023, 04:06 PM #165000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
another question. are those power steering lines? cuz too small for hydro steering. and there is a cut off steering cable. another one i am gonna grab has hydro steering, good powerhead, cracked mid section and a stainless prop. i know. prop. means nothing until you find what pitch the boat wants. but it is way easier to calculate based on what boat does with a given prop than to SWAG from scratch. 17 and 21 inch mercruiser props fit this lower unit? if so i have more to try. and is this essentially a merc alpha without the chebby 350 attached to the other end of driveshaft?
04-01-2023, 05:42 PM #17
Yes very similar lower unit to the smaller merc i/o stuff 15 spline props pretty much all fit the mighty black max
04-01-2023, 06:28 PM #185000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
that is funny cuz the 2.0 ratio mercruiser is for the itty bitty 4 cyl 120. a mail jeep and fiero engine. even the little 305 uses a 1.65 drive. and big blocks like the 1.36 better than the 1.5 that all the 350's run. OTOH a 350 sounds like it is coming apart above 4k...
04-01-2023, 06:40 PM #19Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 307
- 6 Post(s)
Also cross check serial number on the transom bracket against the Welch plug on the block and the build date stamp on the block. On my 2.4/200, the transom bracket is from 1983, BUT the block is a late 1990. Got to be one of the last 2.4/200’s ever made, before the switch to 2.5.
There is a lot of direct interchangeability in these Merc V6’es.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
duckrazee thanked for this post
04-01-2023, 10:24 PM #205000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
i got to get it home and start tearing into it. at 250 bucks, i wasn't even asking them to flip it over. it turned and was all there. and prop shaft was free. so i paid them.
LakeFever liked this post
04-02-2023, 04:46 AM #21
rock thanked for this postpcrussell50, tnelsmn liked this post
04-02-2023, 05:05 AM #225000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
and i started the thread asking about black max stuff cuz i was clueless. thank you all. i am much less clueless now. most of the stuff i found the sellers weren't saying black max. but the pics in the ad had it on the cowls. probably gonna be painted out on any that i run. one more similar question: XR 2-4-6. what years and what is the diff between them? and i am still considering a bigger boat with an 08 175 optimax pro xs. looks like it was never started. but i can't run it. hung on boat but never rigged. and not cheap. all the pumps, compressors and other little pricey stuff on that setup scares the crap out of me. but it comes with a very nice hull...
04-02-2023, 05:17 AM #23
not for tha ally... that little boat would luv a hard hittin' 200.. a good solid hull, motor, set up, prop and all mechanical junk at its best you'll be in tha 90's easy or real close to it... jus one thing.. ya gotta learn how ta drive it!!!
in sw. fl. there are lottsa folks that ya need ta meet that can give ya all kinds a help...............Last edited by tlwjkw; 04-02-2023 at 05:19 AM.
rgsauger, Tomanytoys liked this post
04-02-2023, 05:45 AM #24
XR2... 2.0 produced to 1987.. hyped up 150.. a had different carbs and tuner as to a regular 150.. justa LITTLE bit saltier tha tha regular 150..
XR4 150... first and only attempt at a "steel bore" 2.4 motor.. 1987 to 1991.. mostly aimed at tha bass folks because of tha hp limit in tournaments..
XR6 150... 1991 till 2005.. 2.5 (completely different block/crank/pistons) carbureted motor (all tha XR series were carbureted)... is a stout motor for a 150..Last edited by tlwjkw; 04-02-2023 at 05:54 AM.
pcrussell50 thanked for this postpcrussell50 liked this post
04-02-2023, 05:52 AM #25
did you get tha tilt n trim pump with tha motor?
parts for your motor.....
1984 Outboard 200 [ELPTO] [1200724] - Parts Lookup | Crowley MarineLast edited by tlwjkw; 04-02-2023 at 05:56 AM.
04-02-2023, 06:32 AM #265000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
tilt trim pump there but doesn't work. i built car starters for a few years. it is a 12 volt motor. i will figure it out. plus the next 2 i am gonna get also have the pumps...
04-02-2023, 06:40 AM #275000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
do the carbs have a name? like 4150 holley or carter afb? or just merc 200 carbs? look pretty simple. 2 gaskets and clean em out.
04-02-2023, 07:03 AM #28
Carbs are simple. Float height is critical. Install new needle and seat in each. Be SURE to do proper link & sync afterwards. You’re about to learn a bunch. Have fun!
oh, and stock compression is around 120 psi. That tells the tale for any given mota.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
04-02-2023, 07:11 AM #29
Be sure to delete the oil injection and the black boxes before you run it and use premix
pcrussell50, rgsauger liked this post
04-02-2023, 07:21 AM #30
up through '90 they are termed WH followed by a number.. yours may be 20's? 4 gaskets (two triangle shape sort of on tha inside) always replace (all 4) no mater how good they look.. most WH gaskets are all same no mater tha number....not all will have tha number stamped on 'em.. then tha fun begins on how ta identify what they are exactly.............
'91 ta '95 WMH's
'96 up WMV'sLast edited by tlwjkw; 04-02-2023 at 07:24 AM.
pcrussell50, derekfl thanked for this postpcrussell50, rgsauger liked this post
What are 260s worth these days
By Lake rat Skater in forum General Boating DiscussionReplies: 3Last Post: 08-02-2019, 11:23 AM -
Tuning Mercury 2.4 Black max, what is worth while?
By Roos in forum Technical DiscussionReplies: 53Last Post: 09-17-2012, 01:28 AM -
1989 200 black max Worth?????????????????
By 21eagle in forum General Boating DiscussionReplies: 9Last Post: 11-24-2007, 08:28 PM -
What is a 2.4L drop on worth these days?
By PRODECK1 in forum Technical DiscussionReplies: 2Last Post: 09-05-2007, 04:34 PM -
225HP Black Max 3.0 litre Outboard Engines
By Dtile in forum Props, Setup, and RiggingReplies: 1Last Post: 08-06-2004, 10:41 PM
