Results 1 to 15 of 83
04-01-2023, 05:15 AM #15000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
are black max engines worth playing with these days?
they are all over the place and cheap. i don't have a boat or any engines yet. but i can pick up these old 175 and 200 motors for next to nothing. or is there a reason nobody is buying them? are they sleeved, or plated bores? and is the 30 years of ageing after being run in the gulf of mexico just too much time gone by on aluminum boat motors? i am looking at an old allison 18 that is seriously underpowered as-is. but 400 lbs of V6 may be a bit much weight for it anyway.
04-01-2023, 05:38 AM #25000 RPM
- Mar 2016
- cincinnati, ohio
- 661
- 142
- 32
- 278
- 191
What do you consider next to nothing???
04-01-2023, 05:40 AM #35000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
100 to 1000 bucks. most in the 250 to 500 range. and when did they stop using the black max name?
04-01-2023, 05:48 AM #4
Dave Strong liked this post
04-01-2023, 07:00 AM #55000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
i have read all that stuff. didn't answer any questions. when did they stop using sleeves and start plating the bores? when did they stop putting the words "Black Max" on the cowls? and when did they go from carbs to efi? and how much interchanges with later stuff? are people still running these and if i drag a couple home am i gonna be able to make something workable and reasonably powerful? or am i gonna have a bunch of rusty stainless bolts broken off in aluminum holes and take it all to the dump and get 10 cents a pound and hear the wifey say "I told you so!"?
04-01-2023, 07:14 AM #6
The V6 merc known as black max debuted in the 70’S and is referred to as the most common used motor for high performance outboard applications. Almost all models can interchange parts and mods can be made to the most extreme levels. The 200 black max from the 70’s until the 90’s were chrome bore. Basically the 2.4L were chrome and when they switched to the 2.5L in the 90’s they are steel sleeve. The 2.5 is the most desirable for obvious reasons but the 2.4 can still run hard. The smaller 2.0L 135/150 and some 175 are known strong and run hard too, just not going to mod much past 200hp no matter what you do so if performance is your only goal aim for a 2.4 or better 2.5.
far as im concerned any running black max at 250? Is a buy now item. If it still has the lower unit? 500 is a bargain. Hard to beat the fun you will have with one of these. The prop selection alone makes these motors incredible to use. In the end the prop and the set up is the secret sauce to peak performance.
exceptions to the above are any of the factory hipo race motors they are more uniqueHydrostream dreamin
pcrussell50 thanked for this postpcrussell50, Backmarker liked this post
04-01-2023, 09:01 AM #7
Be careful or your wife may be right. Lots of variables.
RockTeam Junk
04-01-2023, 09:22 AM #8Team Member
- May 2009
- 1,870
- 553
- 73
- 633
- 298
- 6 Post(s)
You must be looking someplace other than craigslist or ebay. On Fort Myers craigslist, there are zero 150-200hp Merc V6's listed that are of the "black max" generation. And of ALL of ebay, there are zero 175-200 Merc V6's listed from the "black max" generation, and two 150 hp Merc V6's listed from the 'black max" generation.
Out here in the west, the 150-200hp Merc V6's from the "black max" generation are rare and bought up quickly when they appear on craigslist. And for much more money than "next to nothing". Parts for these motors are common on ebay (thankfully) and are worth MUCH more than scrap. If you can really get these things for next to nothing, I'd say at the very least you are well set for an ebay business.
The "Black Max" generation is: steel sleeved 2.0l for 150, and chrome bore 2.4l for 175-200. There were a few over-200hp black maxes in EFI, but not many. they are expensive and desirable but "racy" and maybe not as well suited to daily family recreational boating. the "2.5" family replaced the "Black Max" family in around 1991 or so. The EFI generation belongs to the "2.5" family, even though there were also some EFI 2.4's. But there are also carbureted 2.5/150 and 2.5/200 and they are very nice motors IMO. If my 150 and 200hp "black maxes" weren’t so good and reliable, I’d like to have a carbureted 2.5/150 and and an carbureted 2.5/200. But again with my "black maxes" being so good, I just don’t have the motivation to go looking for carbureted 2.5s and re rigging out of my existing 2.0/2.4.
As to the "black max" usability and reliability in day-to-day use, they are fantastically simple and reliable, IME. Couldn't ask for more. As an extreme example, I've been running a used one I bought off ebay with low compression on the top two cylinders for the past seven years and even still, it runs like a top. Never failed me. But it still bugs me so...
...Last summer, I found a used, salt water 2.4/200 that runs pretty well. Paid $2000 for it. Putting some effort into "de-salting" it before putting it into service while I get the top two cylinders in my 2.0/150 bored, even though it still actually runs well.
My opinion, the "black max" family: 2.0/150 (which are steel sleeved), and the 2.4/200 (which chrome bore) are fantastically reliable, great day-to-day use motors... IF you can actually find runners for cheap.
Obviously, a 2.5/150 is going to be way torquier than a 2.0/150, and probably beat it all day long in a race on the same hull. And from what I read on here, the same goes in the 200hp category: the 2.5/200 generally beats the 2.4/200 in racing too. When you can find carbureted 2.5's either 150 or 200, they are generally way more expensive than the 2.0 and 2.4 black maxes. So unless you are needing to race, you might be able to get reliable day to day propulsion for cheaper with a 2.0/2.4 black max.
-PeterLast edited by pcrussell50; 04-02-2023 at 10:32 AM.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
04-01-2023, 09:32 AM #95000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
gonna grab a couple then. thank you all. and any more info will be appreciated.
04-01-2023, 11:25 AM #10Team Member
- May 2009
- 1,870
- 553
- 73
- 633
- 298
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
04-01-2023, 11:41 AM #115000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
of course. i am a very good wrench, but from offshoreonly and the corvette forum, i KNOW that the best and brightest outboard minds-other than the ones that wanna charge me 4k-are on forums like this. i just bought my first. 84 200 hp. still laying on it's side in the seller's yard. i assume 84 as that is the date on the starter. motor spins. steering seems siezed, but it may be the cut off cable that is rusted solid. i think it is a 25 inch. with that little allison i will need a 20 inch mid and lower. i will post the pics i took in a few. gotta log into the site from my phone.
04-01-2023, 11:55 AM #125000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
Here are a couple. is this a 20 or 25 inch? and can somebody point me to a free download of the service manua;? thanks.
04-01-2023, 12:06 PM #135000 RPM
- Mar 2023
- SW Florida
- 461
- 28
- 75
so, is 380 lbs too much on the back of a 675 lb 18 foot bass boat? cuz there are lots of 90 and 115 hp options out there too, but they aren't that much lighter. hell, the 50 merc big foot the boat comes with is 260lbs. not looking to race. too old for 70 mph on up. just wanna drive around and explore the water in this boater's paradise we moved to. and maybe pull up the occasional fish...
04-01-2023, 02:05 PM #14Team Member
- May 2009
- 1,870
- 553
- 73
- 633
- 298
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
04-01-2023, 02:54 PM #15
Looks like 20” to me. Lower unit there should be ratchet type if original. 84 200 might be finger ported too iirc. If so thats a yee haw go fast
What are 260s worth these days
By Lake rat Skater in forum General Boating DiscussionReplies: 3Last Post: 08-02-2019, 11:23 AM -
Tuning Mercury 2.4 Black max, what is worth while?
By Roos in forum Technical DiscussionReplies: 53Last Post: 09-17-2012, 01:28 AM -
1989 200 black max Worth?????????????????
By 21eagle in forum General Boating DiscussionReplies: 9Last Post: 11-24-2007, 08:28 PM -
What is a 2.4L drop on worth these days?
By PRODECK1 in forum Technical DiscussionReplies: 2Last Post: 09-05-2007, 04:34 PM -
225HP Black Max 3.0 litre Outboard Engines
By Dtile in forum Props, Setup, and RiggingReplies: 1Last Post: 08-06-2004, 10:41 PM
