Results 1 to 8 of 8
    Dec 2004
    Easthampton, MA
    Nitro to Electric conversion questions
    Thinking of repowering my Dumas tunnel with the TFL 3660 Outboard. I am new to this electric stuff and had some
    questions, hope someone can help.
    What would I need for an ESC for that outboard?
    Would my “vintage” Futaba AM controller be able to control a new ESC?
    What type battery would I need to power that Outboard?
    And has anyone bought stuff thru offshoreelectrics.com? I posted the same questions to them via email from their website and got back what seemed like a computer generated response that made no sense and answered none of my questions.
    While the Nitro was fun, it’s just not feasible for daily use anymore. Again, I am new to this stuff and am trying to make sense of it, I just can’t wrap my brain around the technical stuff yet.
    Attached Thumbnails Attached Thumbnails 64ECBD89-8C83-4FF8-A975-2CCAB3AAF429.jpg
    Nov 2021
    N. Idaho
    Usually a 120amp would be fine for that size motor, depending on voltage used. Volts×amps=watts.
    Kv of motor, (rpm per volt), is going to be critical when you decide on a battery voltage, and rough prop size.
    Your am transmitter will be compatible, but not the best choice for range, interference, and a fail safe shutoff when you lose signal.
    Offshore electric is great. I don't know if I could recommend the tfl outboard your looking at. I have one that I've never run, and I don't like the length of prop shaft and the tight radius of the flex shaft. It does look awesome.
    My father and I have a whole fleet of tfl mini outboards running on 6s at about 50,000rpm. We do a bit of modification in order to keep the flex shaft in one piece and not lose props when they do break.
    Dec 2004
    Easthampton, MA
    Thank you for all the advice and knowledge Onpad. I’ll be sure to post updates on the rigging and how the runs go. It’s been close to 20years since this boats been wet, can’t wait to have some fun with it again!
  4. Likes OnPad liked this post
    Dec 2004
    Easthampton, MA
ID:	517693Click image for larger version.
ID:	517694Click image for larger version.
  6. Likes OnPad, motexas liked this post
    Dec 2004
    Easthampton, MA
    Motor is mounted. I have to say I am impressed with this thing, at least how it looks and is made. The paint on the cowl is subpar but that can be fixed.
    This mount is my 3rd try at using what I have laying around and it turned out lightweight, not pretty but effective (I hope). I have to work on steering next and then electronics.
  8. Likes OnPad liked this post
    Dec 2004
    Easthampton, MA
    While the motor bracket isn’t pretty, it is made from some leftover InControl foot throttle roller guides. Fits good with the name on the boat!
    Dec 2004
    Easthampton, MA
    Dumb question time. The ESC has 3 black wires to the motor, not
    marked and nothing in the instructions. Motor has the 3 wires, colored red, yellow and green. How do you hook it up to the unmarked ESC? Does it not matter what goes where?
    Nov 2021
    N. Idaho
    Hook it up however, if motor spins backward, reverse two wires.
  1. Mercury Tech: electric oil injection pump conversion kit
    By Barracudamooda in forum Technical Discussion
    Last Post: 07-17-2021, 05:43 PM
  2. OMC Electric Shift sterndrive questions
    By biggercb in forum Technical Discussion
    Last Post: 05-16-2012, 04:16 PM
  3. 90s bravo to mercury six drive conversion..questions...
    By simplyorange in forum Technical Discussion
    Last Post: 06-15-2010, 01:55 PM
  4. 20" to 25" conversion questions
    By CMC in forum Technical Discussion
    Last Post: 04-24-2007, 08:21 PM
  5. Replies: 9
    Last Post: 05-21-2005, 04:53 AM
