Results 1 to 15 of 17
Thread: Misc Merc Parts
    May 2001
    Kentucky
    Misc Merc Parts
    SHIPPING INCLUDED___U.S> ONLY LOWER 48
    3/4 wp cover --SOLD
    Tach 8k-SOLD
    Autometer 60psi fuel gauge -SOLD
    Mercury fat shaft locking hardware $45
    Merc crank (threaded) ring $40
    Fuel Enrichener--$30
    Fuel pump assembly-$30
    Carb linkage-PRICE REDUCED-Sold
    Tiller extension--$35
    Fuel rail connection-$40
    Merc 245 hp HI performance carb intake-$140
    Laser/XRI/Promax 225- 7 petal mod reed plate-$140
    Throttle arm-$28
    5 pin control box harness-$22
    2 hole low water cover attachment-$22
    20" v6 merc shift shaft-SOLD
    Bearing preload tool--SOLD-
    DMT2004 TACHOMETER KIT-$459
    DVA adapter—$65
    Lower mount support plates and covers -$68
    Bleed line port hub-$55
    10 An fittings ,8an nla, and tri adapter—$65
    Stock 260 linkage—$25
    Merc clam shell 200 v6 cover-$35
    Trim harness--$30
    Lot A-$48
    3 metal v6 coil holders-$30
    1-Port and 1- Starboard standard bore used Vertex pistons top guide with washers, --$60 each
    Seal driver and new fish line cutter seal-$30
    Bosch fuel pump holder-$20
    Thrush washers-$20
    Merc v6 motor ignition harness--$35
    Merc 200 v6 heads -2.4- $95
    2.4/2.5 merc carb intake-$65
    Single ram swivel-$165
    Merc v6 piston pins-$50
    Merc v6 ratchet clutch -$30 each
    Misc parts on orange board all of them— $35
    4 pin merc cable- $25
    16 amp 8 tooth steel v6 flywheel-SOLD
    Quick connect fittings for Merc pt assemblies-$65
    Merc VST-$145
    Merc switch box plate-$22
    Merc throttle cable bracket-$22
    Misc fittings right of vst in pic-$45
    All bolts in pic with grommets-$35
    Grommets and flat washers-$22
    4 pin test harness-$45
    New Breaker-$20
    Merc v6 relay harness-$55
    Merc efi intake-$35
    260 exhaust plate and tuner-SOLD
    6 Blue plug wires-$75
    Merc stacks-$85
    Mercury Racing exhaust divider 225/245/260 style new-$365
    Factory antique Mercury Outboard psi gauge-$100
    Allison SS custom fit boat cover—Sold
    Mercury Racing 245 carbs-$185
    Special tools book-$25
    HiPo clutch tools-$65
    TPI-$95
    Crank Holder 13 spline-$30
    Air temp sensor-$40
    HiPo 3/4 short water tube for 15" mid-$105
    Mercury High Performance 245 hp carb Front Half- $415
    Brucato laser plate-$72
    Brucato horn plate-SOLD
    MORE PARTS TO BE LISTED STAY TUNED
    Shipping included ----U.S.only
    Attached Thumbnails Attached Thumbnails 8D3B089E-9379-4E0B-BA24-DA3DA703D48C.jpg   BFA05C17-A300-4129-A178-877F35BCE29C.jpg   7C6D04B5-FFBD-4073-80EB-8BAF0AD8EA6F.jpg   CB6BB976-30EA-4C93-8FAC-87AE19F4F5CF.jpg   BAFE6BDC-4C15-4EFD-88DA-5E8202AB83F4.jpg
    3E3DABF0-256C-4007-84B9-D6D5D6EA9326.jpg   C5F16F46-B07A-4C78-9448-F364CE0124D5.jpg   DDF155E3-6489-4C9B-B74D-9906BE749284.jpg   43C08037-DD84-47F7-B4E5-D7933DD88621.jpg   52B80D55-4FF3-4BB7-9A30-51AB2A079188.jpg
    201821C0-F0D6-41AC-965D-5F8512D4C2CC.jpg   ED581D8F-D827-42FD-80CB-3B412FA5ED9C.jpg   09549334-69A7-4D1F-9B48-A1211D0F0798.jpg   3A38A999-9B4F-4A39-95CD-2FFFC97F417A.jpg   27D72789-76E3-4CE5-989E-B2CBC9926D86.jpg
    24B466AE-BD6E-437D-A7D4-F3BB3DEF172D.jpg   269C2494-7C0C-4D3F-A02B-2A0961552B3E.jpg   7E4DAD4E-5F80-4F3E-B918-52E00FF2BFCB.jpg   F46CA81C-5665-4701-BD6B-70CF05A5B966.jpg   18B41ABD-8461-406B-9AE5-8EB4AC3ED937.jpg
    FFF9149E-D94A-44CB-8EB8-39C68DE28B36.jpg   78EBD7F3-22B1-4B29-BC74-E362AE4083FA.jpg   9A6FD59F-8394-4CBA-A38B-701D1911EE2C.jpg   E1DF844F-4F3A-479C-A831-D29145538286.jpg   9CD23142-DA1D-4FCF-9995-2BC35595F54C.jpg
    133A7220-76B4-47D1-91C8-96FF993ECA80.jpg   E991E822-B1F1-4AB5-A354-8F63E5D90A54.jpg   7EE1507B-D938-4ED7-A24D-ABCE0840B7A4.jpg   07020BB5-2077-4A29-85A3-81265AE62036.jpg   D41C254D-8723-4B5C-BB0A-3356DB270C85.jpg
    2863B253-606E-4CA5-AC82-BB08E1E31764.jpg   D84A4887-F070-4C2E-8F85-7DEFB194DFD2.jpg
    Jun 2014
    United States
    I sent you a private message. Please call me.
    Massapequa NY
    Do you mind posting what you sold the tack for?
    Susquehanna River, central PA
    Id like the brucato plate to mount the box on a horn motor, thanks
    current rides-
    DCB Mach 22, twin 2.5
    2002 Bullet 20 XDC
    1991 Checkmate Pulse 225 Promax
    Jamis Zenith Elite road bike-one old man power
    past rides- four stv's, one 21 liberator, one mirage and a glasstron and a few pontoon boats and a duck boat.
    past power-2.5's, 200, 260,280, drag. 3.0 L-225, 300x
    No more dirtbikes!
    Jul 2004
    Ft. Lauderdale, FL
    Looking for linkage for WMH carbs if you have, let me know.
    Sundance Marine
    May 2001
    Madison, WI
    Beautiful ad! Thank you
  7. Thanks Ace thanked for this post
    Likes tux974 liked this post
    Fort Lauderdale
    Hi I am interested in your 7 pedal front half.
    Does it fit a 200 merc , FF block ?
  9. #8
    May 2001
    Kentucky
    Quote Originally Posted by Mitch S View Post
    It will fit a 2.5- 200 ff block along with others," BUT " sometimes adjustments need to be done to fit the
    crank sealing rings.
  10. #9
    Sep 2021
    Buffalo, NY
    Would I see any gains bolting the 245 front half to my xr4 150?
  11. #10
    May 2001
    Kentucky
    Quote Originally Posted by ctobias1984 View Post
    NOPE not unless you do mods to the entire powerhead .....
  12. Likes ctobias1984 liked this post
    May 2001
    Kentucky
    Tttttt_update shipping included
  14. #12
    clermont fl
    do you still have adapter plate i need one 407 535 0089
  15. #13
    May 2001
    Kentucky
    Quote Originally Posted by josh pomerleau View Post
    YES<$768 shipping included, pics in first post ...
    245/260 style adapter plate for v6 merc motors--- fresh water, staggered tuner, mod water dumps-- nice plate in good condition !!
    Attached Thumbnails Attached Thumbnails 1F85D396-96A6-47EB-AAB7-4B63DCCFF4D5.jpg   1D4A5F7B-C7ED-4C06-A969-13C707643C64.jpg   5EC7B1E2-AC7F-40CA-BDDD-92D9FF97A433.jpg
  16. #14
    clermont fl
    can you please call me 407 535 0089
  17. #15
    May 2001
    Kentucky
    PM sent
  1. Misc parts and 2.0liter Merc parts
    By superboattwin250 in forum Misc. Parts and Accessories
    Last Post: 09-09-2015, 02:29 PM
