Results 1 to 12 of 12
    Oct 2020
    Naples Fl
    Choosing the correct set back jack plate for my boat
    Hi, I have a 2004 Velocity 22CC with a 250 yamaha hpdi 20" shaft. The boat came with a CMC 5 1/2" setback jack plate which recently fried! I am looking to replace it and was wondering if i should go with a bob's or atlas and 6" or 8" set back? The boat ran decent with the other set up, just wanted any thoughts on more setback?
    Thanks
    Attached Thumbnails Attached Thumbnails boat 7.jpg   boat 4.jpg   boat 5.jpg   boat 2.png
  2. Likes rgsauger liked this post
    Mar 2022
    Lake Travis Texas
    Its one of those questions you may get many different opinions on. My suggestions is to not change it with it being a stand up boat. More step back will make boat act lighter. If you were looking for speed and were sitting lower in the boat more set back might have its advantages.
    Jim
  4. Likes hydra-sports liked this post
  5. #3
    Houston, TX
    Very cool boat. Welcome to scream and fly!
    Mar 2010
    Alberta
    Quote Originally Posted by Jim Speros View Post
    I agree, but I can’t imagine the difference between 5.5, 6 or 8 inches making much noticeable difference on his boat anyway.
    08 Checkmate 2100br 250xs
    May 2001
    Maine
    If you are planning to increase set back, be sure to check for possible interference between surrounding cables and wires also how much extra "slack" you have in the wiring and hydraulic steering system if so equipped. Also check for possible steering arm & tilt/trim interference. You may also need a prop "tweak" to really see the setback benefit if you are chasing top speed.
  8. Likes rgsauger liked this post
    Dec 2019
    Spring Lake MI
    As said above it is a can of worms to get another couple mph at best I would imagine.
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
    Pics of it running would help to see where COG is. If it already fly's the nose more set back may not help.
    83 V-King, OPTI. 250 PRO XS on the transom
    Let's Go Brandon, Let's Go Brandon.. Yell it till their heads x-splode.
  11. Likes rgsauger liked this post
  12. #8
    Oct 2020
    Naples Fl
    Thanks guys for your feedback, I spoke with Scott at Velocity and with my current setup a 6" bob's is the direction were going.
  13. Likes NICE PAIR liked this post
  14. #9
    Aug 2002
    waterloo IN
    Get a video of it at full throttle to see the trim of the engine, you want it 90 degrees to the water to maybe one or two degrees tucked in. If it is trimmed out it needs more setback.
  15. #10
    Maybe you could fix what you have, for less $?
    https://thmarinesupplies.com/collect...-lift-actuator
    Let's go Brandon!
  16. #11
    Oct 2020
    Naples Fl
    I will thanks guys.
    Oct 2018
    Tennessee
    Shawn torrente racing makes an 8 inch setback plate that is pretty mean, also hydraulic, and has a pad for preset heights
    (Rip. Whiteally02) -dad
  1. 6" set back jack plate
    By K-Dawg in forum Parts Wanted
    Last Post: 04-01-2015, 12:16 PM
