Results 1 to 3 of 3
Thread: 3L Crank Trigger Re-Location
03-29-2023, 02:18 PM #1
I'm looking for someone that makes, or can make a crank trigger re-location bracket for a 3.0L Optimax. It is so you can use the new electronics on the old blocks.
MAD EFI lists them on their site, and I had talked to him a few years back about it, but he wasn't sure if he would do another run of them. I have reached out again to see, but they show "Out Of Stock" so I have my doubts.
Does anyone have one of these laying around, or where can I get one. I'm pretty desparete, this is the difference between me getting this motor running or not.
Thanks!
www.InjectorService.com
Call/Text - 204-326-0390
03-29-2023, 03:02 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...that's right up dagodiver's alley, here on the board. just need a spec drawing or an actual part. make multiples while your at it...
03-30-2023, 03:45 PM #3
Thanks,
I will let him know if I can find a spec drawing. In the meantime if anyone has one or any more information regarding, PLEASE let me know!
drag crank,has a coller or spacer between bearing and crank is this normal?????
By camaro7081 in forum Technical DiscussionReplies: 29Last Post: 10-22-2009, 09:42 PM -
egt location on a 260
By YELLOWSS in forum Technical DiscussionReplies: 3Last Post: 01-24-2008, 02:38 AM -
location
By joed in forum The Scream And Fly LoungeReplies: 0Last Post: 01-20-2004, 10:56 PM -
Crank trigger sticking
By gtsmpuc in forum Technical DiscussionReplies: 6Last Post: 09-25-2001, 06:49 PM
