Results 1 to 5 of 5
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Mercury / Seastar side mount controls (Gen 2)
    OK so I have a Merc Gen 2 side mount shift/throttle control on my Checkmate that's giving me problems.
    Can anyone give me the part number for a Mercury (and) a Seastar replacement? I might settle for Seastar if Mercury is back ordered.
    I've tried to find both with no luck. The Dometic / Seastar website is horrible...
    Thank you in advance.
    Allison Grand Sport Elite with a Dave Driefort built 225x
    Jan 2020
    Pinole, Ca
    Gen 2 side mount with a built-in wiring harness/key or is it just a throttle/shift panel mount box?
    If it has a key switch in it then do you have a 8 pin or 14 pin harness?
    This is a side mount 8 pin for older mercs but takes gen2 cables
    https://www.partsvu.com/remote-contr...8aAkNFEALw_wcB
    Side mount 14 pin is
    8M0138641/8M0138644
    panel mount gen2 is
    883710A03
    Dec 2017
    8M0138641/8M0138644
    panel mount gen2 is
    883710A03
    Hey Jacob! The motor is a 2017 Merc Pro XS 250 Optimax. The control box is a 2018 Gen 2. 883710A03 looks right.
    Thanks!
    Dec 2017
    TILT switch?
    Curious about the difference here between
    CHX8051P and CHX8052P ?
    Trim switch or Trim and Tilt switch?
    Attached Files Attached Files
    Jan 2020
    Pinole, Ca
    Yeah its either a 3 wire or 4 wire switch. 3 wire trim switch or 4 wire trim+tilt switch. 4 wire is made for sterndrives (and some outboards) that have a trim limit switch. The switch is momentary 4 positions: down-off-up-up
  1. Single lever side mount controls vs two lever side mount controls?
    By Wellcraft26 in forum General Boating Discussion
    Last Post: 12-04-2019, 07:32 PM
  2. WTB Mercury side mount controls
    By CHEVYMAN434 in forum Parts Wanted
    Last Post: 10-21-2017, 07:55 PM
