Results 1 to 3 of 3
    Jun 2012
    Custom cut 2.5 o-ring heads
    Custom 37cc cnc machined o-ring heads for a standard bore zero deck height oring motor. Heads have fully machined chambers with a .043" x 2 degree squish pocket. One of the heads has a small casting flaw. Had them listed on fb for $500 shipped but at this point i will accept the first reasonable offer or trade for a empty swept skeg big window cle case. Call or text 810-701-2484
ID:	516914Click image for larger version.
ID:	516915Click image for larger version.
    Halifax, Nova Scotia 88 Mallard Drive B3Z4L5
    will these heads give more compression or less than stock?
    Jun 2012
    More then stock. What hp motor would you be putting these on?
  1. O ring heads or Gasket heads
    By Krazymaan in forum General Boating Discussion
    Last Post: 02-12-2017, 09:48 AM
  2. Custom Billet Heads vs Stock Cut Heads
    By 95RapidRiot in forum Technical Discussion
    Last Post: 01-13-2008, 02:43 PM
