Results 1 to 4 of 4
03-23-2023, 01:02 PM #1
300XS Compressor Water Inlet Hose
I recently purchased a used 300XS for a replacement.
It has a check valve installed in the water line from the adapter plate to the compressor.
What is this for and what is the advantage of having it?
03-23-2023, 01:44 PM #25000 RPM
- Dec 2017
- Okeechobee FL
- 172
- 29
- 19
- 194
someone installed an inline strainer, maybe to take out the one in the mid to make it easier to service.
03-24-2023, 10:43 AM #3
I'm not sure that is a fantastic idea. Id go back to the stock strainer personally. The compressor is connected to the tell-tale. No tell-tale = no compressor cooling. Easy.
www.InjectorService.com
Call/Text - 204-326-0390
03-24-2023, 12:53 PM #45000 RPM
- Dec 2017
- Okeechobee FL
- 172
- 29
- 19
- 194
300xs compressor
By carolina in forum Technical DiscussionReplies: 0Last Post: 03-21-2020, 12:52 PM -
Replace air compressor 300xs yes or no?
By darkdream in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 04-16-2018, 09:43 PM -
300XS compressor reeds
By skater308 in forum Technical DiscussionReplies: 5Last Post: 04-20-2017, 07:40 AM -
300XS Air Compressor
By mthaler in forum Technical DiscussionReplies: 5Last Post: 07-03-2014, 07:01 AM -
Mercury Tech: 300xs compressor failure
By Bjorn08 in forum Technical DiscussionReplies: 5Last Post: 06-12-2014, 02:16 AM
