Results 1 to 7 of 7
03-22-2023, 12:04 PM #15000 RPM
- Jul 2013
- medellin colombia
- 347
- 9
Can a 30” Yamaha 300 4T lower unit input shaft be cut down to 25” and be resplined ?
I bought a pair of 30” Yamaha 300 4t lowers for the 4.2L engines for parts but have 25” engines can the input shafts be cut down to 25”. Thanks in advance for any info, RM
03-24-2023, 10:51 AM #2
Those have a tapered shaft, so you can't cut and respline. You have to cut the middle out and weld them together.
www.InjectorService.com
Call/Text - 204-326-0390
03-24-2023, 07:38 PM #35000 RPM
- Jul 2013
- medellin colombia
- 347
- 9
03-27-2023, 04:01 PM #4
I'm not sure who does the work. Maybe phone Chris Carson? Mine is being done up here in Canada. I guess we will find out how well they hold up. The guy who is doing mine mills a nub in one end, and a socket in the other to get a nice fit-up, and then welds them together.
04-04-2023, 09:03 AM #5
Decades back I welded up the shaft diameter so splines could be cut in the shaft, this was not on a marine part but the task is the same.
I used TIG on that job but expect a MIG man with the proper spool of wire can do a sweet job in less time.
Doing it this way greatly reduces the need to re-straighten the shaft.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
04-04-2023, 06:39 PM #65000 RPM
- Jul 2013
- medellin colombia
- 347
- 9
04-04-2023, 07:46 PM #75000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
buy a 25 shaft.
CLE lower Unit Good case busted input shaft or drive shaft
By CRLmotorsports in forum Lower UnitsReplies: 14Last Post: 09-25-2014, 06:13 PM
