Results 1 to 2 of 2
Thread: smartcraft to lowrance
03-19-2023, 03:14 PM #1
Electronically disabled member needs help hooking smartcraft to lowrance hds. motor is a 300xs and currently has no smartcraft but does have the hds. Need to know what all it is I need. Thanks.
RockTeam Junk
03-20-2023, 01:40 PM #2
If there is already a smartcraft junction box at the dash then all you need is:
NMEA gateway (p/n 8M0165589)
NMEA backbone
NMEA drop cable from lowrance to backbone.
If there is no junction box at the dash then he needs to install one. If the boat presently has a 14-pin key switch harness then the plug is already there...you just plug the junction box in and screw it down. If it has a 9-pin wiring harness then he needs to run a blue cable (p/n 879982T20 for 20ft) from the engine up to the junction box.
lowrance hds-7
By Ajskennels in forum Misc. Parts and AccessoriesReplies: 1Last Post: 06-16-2017, 05:24 PM
