Results 31 to 43 of 43
04-06-2023, 10:40 AM #31
Need something to break water tension, sanded hull, golf ball boat, step hull, or wind riffle all work better than the glass smooth, or frosted cake camp.
04-06-2023, 12:12 PM #32Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
Blueprinted pad
04-06-2023, 06:48 PM #33
Xstream is that the final surface finish?
04-07-2023, 05:33 AM #34Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
Yep, sanded with 360 grit. Notice where the hull rides in the pic? My bottom tune gave me the ability to not have to use any trim to lift the bow. Check the trim angle in the pic. Faster I go, the more I trim it down. All the thrust pushes the boat fwd and is not wasted. Picked up a few mph The 250 opti pushes the boat real well. 270 hp
04-07-2023, 06:46 AM #35
I havent sanded mine yet but i was only going to do the pad. Now you got me wondering. I might try it in stages just to see the difference. 270hp i bet that thing moves out, wow
09-15-2023, 09:39 PM #365000 RPM
- Jul 2003
- ga.
- 198
I b.p.ed my pad, the factory g.c.finish was like dimples and i probably took .010+ off to get it flat. I left a 440 grit sand finish on it and have been running it for years with no lose of speed and have not resanded the pad, the water has taken that finish off. It runs at about 6 degrees on the water for best speed and packs the air best running that flat to the water. Gain right at 3 mph.
09-16-2023, 08:56 AM #37
09-16-2023, 09:05 AM #38
I've always used a 48"x4" aluminum channel
Buy coils of 4 inch sand paper, more for first phase of getting the last 6-8 ft level
Then use 30" 4 inch wide3m hookit / https://www.industrialgeneralstore.c...BoCfHsQAvD_BwE
Sand with what ever makes you happyWe have invented the world; WE see
09-16-2023, 10:51 PM #39
But researchers from UCLA have found that bumpiness can sometimes be better.
"A properly designed rough surface, contrary to our intuition, can reduce skin-friction drag," said John Kim, a professor in the mechanical and aerospace engineering department at UCLA. Kim and his colleagues modeled the fluid flow between two surfaces covered with tiny ridges. They found that even in turbulent conditions the rough surface reduced the drag created by the friction of flowing water. The researchers report their findings in the journal Physics of Fluids.
The idea of using a rough surface for reduced drag had been explored before, but resulted in limited success. More recently scientists have begun experimenting with rough surfaces that are also extremely difficult to wet, a property called superhydrophobicity. In theory this means that the surfaces can trap air bubbles, creating a hydrodynamic cushion, but in practice they often lose their air cushions in chaotic flows.
The ULCA team chose to model a superhydrophobic surface design that another group of researchers at UCLA had already observed could keep air pockets entrapped, even in turbulent conditions. The surface was covered with small ridges aligned in the direction of flow.
The researchers modeled both laminar and turbulent flows, and unexpectedly found that the drag-reduction was larger in turbulent conditions. The irregular fluctuations and swirling vortices in turbulent flows on smooth surfaces generally increase drag, Kim explained. However, the air cushion created by the superhydrophobic ridges altered the turbulent patterns near the surface, reducing their effect, he said.
The team expects insights gleaned from their numerical simulations to help further refine the design of rough, drag-reducing surfaces. Further down the line, such surfaces might cover the undersides of cargo vessels and passenger ships. "It could lead to sig
09-21-2023, 04:10 PM #40
Way back when...
10-01-2023, 07:43 PM #41
When a golf ball is hit it spins backwards. The dimples on the ball pushes a wedge of air under the ball as it flies and spins which makes it fly longer. There is probably a drag reduction factor because the top and rear of the flying ball is textured not smooth. But a round ball spinning through the air has no relation to a flat surface sliding across water. I can tell you from my own experience building RC race boats that a 400 to 600 grit sanded bottom makes a noticeable difference.
As far as air bubbles...remember the boat is supported by water. Even when the boat is on the pad there is a certain amount of water displacement that is constant as the pad pushes down into the water. You introduce a lot of air bubbles and guess what happens...less water, less support. A sanded surface reduces surface tension but the scratches are fine enough to not create drag.1970 15' Allison/135 Chrysler stacker
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
10-01-2023, 08:04 PM #42Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
The balls dimples provide lift like an airplane wing. From my understanding, the sanded bottom carries water in the surface scratches providing a water to water interface. Which reduces friction. And the bubble theory has been proven by making intense bubbles under boats and it caused the boat to sink since air can't support it. JM2cts.
10-01-2023, 08:25 PM #43
Years ago I got into high performance surf skis...racing kayaks. A lot of things are different in making a displacement hull go fast vs a planing hull. The rudder on a racing kayak is shaped like an airplane wing equally on both sides, thick at the front and tapering to a point at the rear. The rudder on a high speed boat cannot be shaped like that as the sides of the rudder will lose pressure causing the rudder to shake left and right. It makes you think!
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
Hull blueprinting
By Matt Torino 150 in forum Fiberglass and Composites DiscussionReplies: 0Last Post: 02-09-2019, 11:37 PM -
Hull blueprinting
By CHICKENHAWK in forum General Boating DiscussionReplies: 7Last Post: 08-08-2013, 03:42 PM -
Blueprinting a hull
By stickbait in forum Fiberglass and Composites DiscussionReplies: 48Last Post: 04-01-2012, 05:48 PM -
blueprinting a hull
By meat in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 12-07-2009, 09:25 PM -
Hull Blueprinting
By Chris Gerber in forum General Boating DiscussionReplies: 4Last Post: 09-12-2008, 11:07 AM
