Results 16 to 30 of 43
03-27-2023, 10:21 AM #166000 RPM
- Nov 2006
- 1,526
- 14
- 133
- 74
- 649
- 36 Post(s)
rgsauger liked this post
03-27-2023, 11:49 AM #17
03-27-2023, 12:24 PM #18
I forgot about marine tex. I used that to repair the chips on my first stream. Worked great
03-27-2023, 12:30 PM #19
Someone spread marine tex on the bottom of my boat, it looked like a birthday cake. It definitely ain't fallen off.
03-27-2023, 10:17 PM #20
well that’s me. Dang thing occasionally gets a mind of her own and hooks to port. I have had it be aggressive and I have had it just make a slow forceful hook to port. Both of them suck and scare the chit out of me! I had it happen again a few weeks back just when I thought I was over it.
I shaved 54 lbs off of starboard side and 12 or so off of port. Plus I’m down 30lbs so 85 off of starboard. 100 total. And now I have to learn to drive the sumbitch all over again. Extreeeeeeeeemly trim sensitive.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
OnPad liked this post
04-05-2023, 06:56 AM #21
straight and balanced is important, smooth not so much, you don't see many smooth golf balls!
04-05-2023, 07:01 AM #22Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,206
- 1038
- 380
- 4479
- 2065
- 8 Post(s)
04-05-2023, 07:04 AM #23
doesn't need to spin creates it's own lift!
04-05-2023, 07:40 AM #24Screaming And Flying!
- Jun 2007
- 9,206
- 1038
- 380
- 4479
- 2065
- 8 Post(s)
Jimboat liked this post
04-05-2023, 08:04 AM #25
Please do some investigation before posting your personal thoughts and possibly misleading people! I wish Owen Boris RIP was still with us,sure he could shed some light on the conversation being an Avro|Arrow engineer and speed record holder with his Alison,you might listen! I was cutting teeth rigging in those stables and examining setups when he was setting records!
if smooth is fast, why put a step in a hull, to introduce air to break surface tension, dimples do the same for a lighter boat!
Tomanytoys liked this post
04-05-2023, 03:20 PM #26
The consensus seems to be 400 grit texture for the pad and primer or raw aluminum for the lower unit. Have yet to see anyone run or suggest a golf ball finish but I did know a guy who built a race engine with dimples in the intake ports. Never did see how that worked out for him but I always remembered seeing it. Water skis ( at least the ones I like ) have a slightly textured bottom finish. Too slick and shiny I did not like the feel. Ironically I felt the rougher finishes had better bite, maybe its a hydro wedge thing, dunno, beyond my pay grade. Most of the AVRO engineers went to work at NASA after AVRO folded shop.
04-05-2023, 05:13 PM #27
I am with Lake fever on this. I won't argue whether some allison may have had dimples on its bottom or not but, I won't believe for a second the alleged dimples were on the pad and/or made it faster. The way air moves around something is entirely different from the way water acts.
I've seen a lot of race boats in the last few decades. I looked closely at the winning ones. I don't ever recall seeing a golf ball dimple on any one any where.Jim
04-05-2023, 08:18 PM #28
more than one allison had it! you've probablly never seen a 3 ft. long gearcase but doesn't mean they didn't exist or didn't work! I don't think we have many mach speed aircraft engineers chasing boat speed records these days is likely were really only chasing "smooth"
pretty sure the first guy to put a lip on the pad and saw improvement was told he was full of **** as well!
04-05-2023, 08:47 PM #29
Some people have bottomless checkbooks funding their go fast boats. If its out there and worthy it would be on display somewhere.
Jim
04-06-2023, 06:20 AM #30
Id like to see results on the golf ball dimples. Plus this would be hard to achieve in real application. Can you imagine trying to pull a dimpled hull out of a mold without wrecking it? There is the option of some sort of top coat. I havent seen anything like this anywhere, ever. So maybe your onto something but i’ll be leaving mine at 400grit. Post up the results before after would be interesting to see. I doubt youd realize 1mph difference but i sure would love to be proven wrong
Keith E. liked this post
Hull blueprinting
By Matt Torino 150 in forum Fiberglass and Composites DiscussionReplies: 0Last Post: 02-09-2019, 11:37 PM -
Hull blueprinting
By CHICKENHAWK in forum General Boating DiscussionReplies: 7Last Post: 08-08-2013, 03:42 PM -
Blueprinting a hull
By stickbait in forum Fiberglass and Composites DiscussionReplies: 48Last Post: 04-01-2012, 05:48 PM -
blueprinting a hull
By meat in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 12-07-2009, 09:25 PM -
Hull Blueprinting
By Chris Gerber in forum General Boating DiscussionReplies: 4Last Post: 09-12-2008, 11:07 AM
