Results 1 to 7 of 7
    Mar 2002
    Pensacola, Fl.
    Sportmaster Driveshaft part #
    I have two part numbers for the sportmaster driveshaft
    I need one for a standard rotation 15''
    848449A4
    or
    848449A5
    Not sure of the difference?
    Thanks Stoney
    Jan 2020
    Pinole, Ca
    848449A4 is 15"
    848449A5 is 20"
    LH and RH use the same driveshaft.
    I think I have 4 good used if you are looking for a used one.
    Also, you probably know this, but getting a 3.0L shaft new and having it cut and resplined costs damn near half of a new 2.5L 15" shaft.
  3. Thanks stoneman thanked for this post
    Likes Hydro2.5 liked this post
    Mar 2002
    Pensacola, Fl.
    Thank you! I forgot about the 3.0 shaft pricing, this is my first time replacing one!!
    Appreciate it!
    Stoney
    Oct 2016
    Sweden
    Also the 3.0L won’t rust.
    South Africa
    848449A4 is 15"
    848449A5 is 20"
    2.5 and 3.0 Sportmasters use different waterpumps. In your valued experience, can the 3.0 driveshaft be modded to accomodate the smaller 2.5 SM water pump.?
    Which 3.0 driveshaft length (number) would you recommend to create a 20" 2.5 ltr Sportmaster deiveshaft, considering resplining requirement?
    Thanks in advance, regards, Wolfgang (South Africa)
    Susquehanna River, central PA
    A 25” dual bearing 3.0 driveshaft is part number 881942. Chris Carson cuts and resplines them for about $175. He also cuts the water pump keyway a little longer or something so it works just fine in the 2.5 sporty
    current rides-
    DCB Mach 22, twin 2.5
    2002 Bullet 20 XDC
    1991 Checkmate Pulse 225 Promax
    Jamis Zenith Elite road bike-one old man power
    past rides- four stv's, one 21 liberator, one mirage and a glasstron and a few pontoon boats and a duck boat.
    past power-2.5's, 200, 260,280, drag. 3.0 L-225, 300x
    No more dirtbikes!
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by wolfgangb View Post
    I do lots of them,cut,respline,harden,and lower the waterpunp key area,Chris
  9. Likes luv2gofast liked this post
  1. Replies: 0
    Last Post: 02-23-2017, 05:27 PM
  2. Need part # for 20 inch driveshaft for 3 litre sportmaster
    By Skater 32 in forum Technical Discussion
    Last Post: 06-30-2010, 05:29 PM
  3. OMC driveshaft Part Number
    By jrpromax in forum Technical Discussion
    Last Post: 02-27-2004, 08:24 AM
