Results 1 to 5 of 5
03-09-2023, 09:43 PM #1
2004 Mercury 250 EFI, 385hrs, freshwater.
I have a 2004 250efi, this is the newer version with the updated electronics, ECU, Smartcraft, Oil injection system and downdraft intake/throttle body. This is not an Optimax, no air pump. 20inch mid. This has the lighter weight cowl like the newer motors, not the heavy one like the earlier 3.0L had. I purchased it about 4 years ago from a guy in Tennessee, it has only been used in the St. Johns River around the Lake George area. I had this on a Hurricane deck boat (ran 59.7gps), my deck boat had a 115hp but is rated for a 150hp, that is why it has the 150hp stickers. I always used Pennzoil Performance Plus oil. I sold the boat to a friend and I told him it was due for lower unit service, gear lube, water pump impeller etc. He actually purchased the parts but never had it serviced. One day his wife and him were out and the lower unit locked up, he ended up getting a new 115 Suzuki and I purchased the motor back. He kept his boat on a lift about 1/8th of a mile from my house on the St. Johns. Last time I remember seeing the hours it was around 370ish, my friend probably put maybe 10-15hrs I would guess as he is only down on weekends. I have the oil tank that will go with it. I have a side mount Mercury control with key switch/harness that is available for $100. I will give you the water pump kit, it's the complete one with the stainless housing etc. I think I also have the gear lube and washers. The input shaft of the lower unit is locked up, the prop shaft spins freely. I have not opened up the gearcase, i'm not sure if the dealer that sold him the new 115 Suzuki did. The pics aren't the best as the motor has been sitting for a few months in my dusty shop under a blanket. The cowl is really nice except for a couple decals peeling, I always had a motor cover on it. There is no corrosion around steering shaft etc. The mid could use a good wash/wax. No trades. I have a gantry crane to help load. Located in Welaka, FL, about 20 miles south of Palatka, 10 mile north of Lake George. prop not included. $5500.00
1990 Viper 140 crossflow
2011 Sea Hunt 232 Ultra
1995 Laser 380
1984 Reaction 19 project.........
05-25-2023, 03:02 PM #25000 RPM
- Jun 2004
- miami
- 115
- 12
Still available?
05-25-2023, 03:17 PM #3
06-03-2023, 07:05 AM #4New Member
- May 2023
- Ct
Is this still available?
07-12-2023, 02:44 PM #5
Would you sell just the powerhead?
1975 switzer hugger
1977 switzer gl20
1976 Mercury 1500 w/Trim - Freshwater Only - Cheap
By FUJIMO in forum Ebay Listings and Other Internet ListingsReplies: 5Last Post: 05-24-2017, 02:23 PM -
Mercury 220 Laser XRI Freshwater
By deCler in forum Outboard EnginesReplies: 12Last Post: 10-28-2014, 08:57 AM -
Mercury 3 liter midsection 20 inch freshwater
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-13-2013, 08:20 AM
