Results 1 to 3 of 3
    Oct 2022
    Eastcoast
    Johnson/Evinrude fast strike 150 help needed
    I Have the standard johnson 150 cross flow v6 believe it’s a 97 or 98 and looking to replace reed valves, heads and carburetors but can’t seem to confirm correct carburetor or throttle body numbers for fast strike 150 (as they have the bigger carbs and I believe I have the smaller ones) already have the other parts also have heard you can weld the exhaust tuner up to gain more performance any help would be great thanks
    Sep 2008
    charlestown, ri
    1st off its a looper, 2nd why are you replacing the reeds? what are you doing this for?
    May 2001
    Hickory NC
    Post your model number. Better in the tech section.
  1. 1997 Evinrude Fast-Strike 175
    By theonlysteve in forum Outboard Engines
    Last Post: 09-20-2021, 06:28 PM
  2. 98 Johnson 150 fast strike
    By monzass24 in forum Technical Discussion
    Last Post: 06-04-2014, 08:28 PM
  3. OMC Tech: Johnson 175 fast strike
    By cjb730 in forum Technical Discussion
    Last Post: 08-15-2010, 11:55 AM
  4. Need Crank for Johnson Fast strike 150
    By jake131 in forum General Boating Discussion
    Last Post: 03-06-2009, 01:59 AM
  5. 97 Johnson 150 HP Fast Strike
    By ChubChaser in forum Technical Discussion
    Last Post: 03-04-2002, 09:21 AM
