Results 1 to 4 of 4
03-02-2023, 07:05 PM #15000 RPM
- Jun 2003
- 299
Offshore stainless plate behind the powerhead steering
A man was telling another guy that with the stainless plate that he did not need the motor mounts underneath on a mercury 200up V6
03-02-2023, 07:21 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Yes on a 1 peace plate..............
03-02-2023, 08:15 PM #35000 RPM
- Jun 2003
- 299
So you do not need the top motor mounts when you use the one piece plate...correct?
03-02-2023, 10:25 PM #4The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...on an older mercury v-6 200, with the standard powerhead sandwich adapter plates under the powerhead, yes, you definately use the upper mounts. only know one company that made stainless steering plates back in the day, that actually went right under the powerhead, using the stock/standard sandwich plates, and that was latham marine. latham would also machine down the thickness of the stock 200 adapters to accept those special thin steering plates. it was a long time ago & those particular s.s. steering plates are no longer made by latham & have'nt been for decades. latham later came up with a different design plates that attached to the standard 200 by a different means. now, as dave above mentioned, if you exchange the standard 200 merc upper motor mount sandwich plates for a solid upper powerhead adapter plate, that does not have rubber mounts, but simply two large studs in the front of it, than thats another design rear s.s. steering plate design & attaching method...
NICE PAIR liked this post
260 HP Stock 2.5 Powerhead on Offshore mid and rebuilt powerhead - Local P/U only
By csorensen in forum Outboard EnginesReplies: 4Last Post: 06-27-2019, 04:04 PM -
Offshore Stainless marine actuator
By AMERICANRAM in forum Misc. Parts and AccessoriesReplies: 0Last Post: 10-12-2017, 05:18 PM -
Wing Plate 2.5 Mercury IMCO stainless steel PAIR ram steering $350
By Brad Zastrow in forum Misc. Parts and AccessoriesReplies: 1Last Post: 03-23-2016, 04:58 PM -
Offshore steering wing plate 300x 300PM Taylor 15"
By Todd D in forum Misc. Parts and AccessoriesReplies: 0Last Post: 06-18-2015, 09:35 PM
