Results 1 to 3 of 3
    Nov 2013
    135 blackmax carbs.
    I've searched high and low. the discussions on carburetors around here is honestly to a point of ridiculous, the amount of part numbers and styles. I'm confused on a not so complicated matter here.
    Can I bolt any old 150hp carb(later model, no accelerator pumps) to an old 1990 135 2 liter with little bore pumper carbs. or should I be looking for a set of 150 carbs of the same generation with the accelerator pumps, as in from a motor that certainly uses the same exhaust plate, tuner, etc.
    to ask in another way, will a set of common, late 90s 150 fishing carbs work on my 135 that definitely has a different exhaust tuner and expect not to make any jetting changes.
    Jan 2020
    Pinole, Ca
    Yeah.
    Try it.
    You don't need the pumpers for your motor. Thats really what it seems like you are asking. No your intake manifold/motor does not specifically need the pumpers.
    Houston, TX
    If you still have stock reeds, now’s the Time to put in a set of CCMS reeds.
  1. 150 blackmax
    By jhalleqdt in forum Outboard Engines
    Last Post: 02-07-2018, 08:32 PM
  2. 275 Blackmax
    By brianbecker in forum Technical Discussion
    Last Post: 11-29-2008, 01:37 AM
  3. 2.4 200 blackmax
    By stiletto200 in forum Technical Discussion
    Last Post: 12-11-2007, 10:52 AM
  4. 150 Blackmax
    By Gerben in forum Technical Discussion
    Last Post: 04-04-2002, 07:42 PM
  5. 150 Blackmax?
    Last Post: 01-22-2002, 06:53 PM
