Results 91 to 105 of 118
02-12-2023, 11:11 PM #915000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
02-15-2023, 07:36 PM #925000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
Well, I got my "new" used ebay 15" prop and it looks to be in pretty good shape. I slapped it on there to give it a try before my new propco cupped prop comes in.
However, my new tach doesn't work any better than the last one. I tried moving the signal wire to the other brown rectifier wire and still nothing. I put my multimeter on the signal wire and then crank it and does change value from constant to jumping. Any thoughts on where to go from here?
02-15-2023, 07:55 PM #93
Is your tach reading 1/2 the actual rpm... or zero... or what's the symptom?
02-15-2023, 08:07 PM #94Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
02-15-2023, 08:12 PM #955000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
02-15-2023, 08:49 PM #96
Spaceman Spiff thanked for this post
02-15-2023, 10:25 PM #975000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
02-15-2023, 10:33 PM #98
You could just put your.voltmeter on the battery (+) and (-) posts before and after you start the engine... if it's charging the voltage should be higher when it's running.
02-15-2023, 10:35 PM #995000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
02-15-2023, 11:14 PM #100Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Don't think that is regulated, just a rectifier which if failing will lead to more.
Over charging will likely be part of norm but when you spin even higher rpm. You need a good dual purpose or marine type battery, not just a thin cheap maintenance free or deep cycle.
I'd get a new rectifier regulator on it before anything. I don't think that produces more than 10A , CDI has a piece for it that is common to used on L6 Mercs as the fix. Actually a OMC piece for small motors too. But a cheapo type brand could also be available.
02-16-2023, 11:57 AM #1015000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
Wtf
02-16-2023, 11:57 AM #1025000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
This is the rectifier isn't it? That red wire there has worked for for several runs as my tach signal wire. I should mention that when i got this motor, the original tach was running off of the signal wire from the controller. I read somewhere you move wires on the switch box if you want to wire it different. But I don't understand that.
02-16-2023, 02:03 PM #103
Hard to see in pic. A rectifier is triangular in shape. Has 2 mounting screws usually in slots on either side. the two terminals that appear in a pair together get a yellow wire each. The other terminal, the one that stands a bit further from the other two gets a red wire.
It appears a red wire got connected in error to a yellow wire.Jim
02-16-2023, 02:14 PM #1045000 RPM
- Sep 2022
- Portland, OR
- 133
- 56
- 20
The red wire connected to the yellow lead is my tach signal wire. It worked fine there for several runs.
The rectifiers i find online as replacements for my motor look nothing like what i have here.
02-16-2023, 02:15 PM #105
This is a rectifier. The lower terminal is marked with a + for the red wire. the other two get a yellow wire each. The gray tach lead can connect to either one.
If one side does not offer a tach signal you can switch to other. If a yellow does not offer a tach signal the rectifier is bad. A rectifier with just one yellow with a signal will run. However, it will not charge. Connecting a red wire to a yellow lead likely damaged the rectifier. A loose battery connection will also damage a rectifier.Jim
Spaceman Spiff thanked for this postDavid - WI liked this post
Help me make my Glen L Stiletto Wooden boat FASTER!! (Advice needed)
By 80's old school in forum General Boating DiscussionReplies: 98Last Post: 06-20-2019, 11:52 AM -
Need to make Eliminator Jet boat go faster!
By lk40hp in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 07-01-2016, 05:41 PM -
Make My CLE Faster
By Liqui-Fly in forum Technical DiscussionReplies: 19Last Post: 04-24-2003, 07:57 AM -
10+ reasons to make your boat faster.David Letterman style
By raceboatrus in forum General Boating DiscussionReplies: 4Last Post: 12-06-2002, 09:30 PM
