Results 1 to 5 of 5
    Nov 2013
    Merc Zero Effort control cables
    Ive trying to understand what cables these need. I have the hook ends that would thread to a 33c cable. But a mercury control uses a universal cable with a mercury adapter on the engine side? am i missing something here?
    Is there any way to re use my standard merc cables with the stainless loops on the control side? push the pin out and press it back in with the cable in place?
    any help would be appriciated.
    Mar 2022
    Lake Travis Texas
    You should be able to re use the ends.
    If your replacing cables look into U flex extreme line of 33 c type. They also offer merc end adapter kits
    Jim
    Jun 2018
    Orlando
    The Mach Zero cables are also a very good, highly flexible option, if you are replacing cables.
    Mar 2022
    Lake Travis Texas
    Mach Zero is a u flex cable. Very nice.
    Jim
    Nov 2013
    went with u-flex extremes. been using uflex for all my steering rams, hoses, cables for a little while now. very nice quality.
