Results 1 to 5 of 5
Thread: Sportmaster water pump question
02-01-2023, 06:55 PM #1Member
- Jul 2009
- Maine
- 94
- 20
- 27
- 19
Are all 2.5 Sportmaster gear case water pump outlets 0.75” ID? The reason I ask is I’m looking for a sleeve and seal for the 0.75” outlet and don’t want to order the wrong part. Thanks!
Rich E.
17' Action Marine/2.5 Pro Max 200
"Badges.........We don't need no stinkin' badges........"
02-01-2023, 07:36 PM #26000 RPM
- Aug 2015
- Southeast
- 1,058
- 134
- 79
- 48
- 614
280 and maybe 260 uses a larger water tube, therefore different pump housing than others such as 225 promax. I can't say for sure if 3/4 is the standard or the larger option. I'm guessing 3/4 is the larger one. Somebody that knows for sure will probably probably chime in. Or you could check the water pump on a 280 vs a 225 promax on a parts site and see.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
Old_Skool thanked for this post
02-02-2023, 08:33 AM #3
3/4 water tube seal
26-88397 SEAL
3/4 water tube Guide Sleeve
23-847685 SLEEVE 1973 Viper - sold
1978 Viking - sold
1995 XB02
02-02-2023, 08:35 AM #4
Now I would say, I have found the guide tube in aluminum as the plastic one is 65.00!
I bought this and have not used it yet in any of my applications but will be sooner or later. Seems to fit well in the housing but just not as snug as the plastic guide tube.
https://www.speedymetals.com/pc-4588...-aluminum.aspx1973 Viper - sold
1978 Viking - sold
1995 XB02
02-02-2023, 10:19 AM #5Member
- Jul 2009
- Maine
- 94
- 20
- 27
- 19
Thanks, RJ!! That was exactly the confirmation I needed. I hate to spend $65 on a piece of plastic, but I will since it’s needed.
Rich E.
Sportmaster water pump cover question.
By Carter Powell in forum Technical DiscussionReplies: 5Last Post: 07-11-2015, 11:00 PM -
By jdewaard in forum Technical DiscussionReplies: 13Last Post: 11-20-2013, 03:46 PM -
sportmaster water pump
By maverick1 in forum Technical DiscussionReplies: 2Last Post: 06-30-2006, 04:05 PM
