Results 1 to 4 of 4
    Jun 2019
    patchogue
    Any info on this mercury lower unit?
    Hey guys I recently came across this mercury lower unit and I don't have much information about it.
    The number on the casting is - 1623-6046 Anyone familiar with this lower unit?
    I couldn't find much online however I did find this thread - https://www.screamandfly.com/showthr...unit-ID-1500XS
    From my limited understanding from the thread this is a 1500xs lower unit? 20"?
    Anyone have any more information?
    Also it is cracked. Is this a keeper? Should I repair it?
    Thank you !
ID:	515090 Click image for larger version.
ID:	515091 Click image for larger version.
ID:	515092 Click image for larger version.
Name:	Paper graph lower unit.jpeg
ID:	515093 Click image for larger version.
    Pekin, IL
    Sad to say but that one is probably toast.
    Rock
    Team Junk
    Jan 2020
    Pinole, Ca
    Water+salt = expands when it dries and cracks casings
    Water+freezing = expands and cracks casings
    Sad to see a special case like that split but it would take a lot of money to put that back together...if you can even find an aluminum welder who will touch it after its been in so much salt. Most likely if you weld on that the metal will magically disappear while you are tryna weld.
    Houston, TX
    Big Paper weight. Welcome to scream and fly!
  1. Contact Info for Titus Lower Unit Mod's
    By DXDY Freak in forum The Scream And Fly Lounge
    Last Post: 12-07-2016, 11:17 PM
  2. Mercury Tech: Verado lower unit info
    By Go Time in forum Technical Discussion
    Last Post: 09-16-2014, 04:51 PM
  3. X-115/GT115 Lower unit info
    By Old fiberglass in forum Technical Discussion
    Last Post: 04-19-2003, 07:51 PM
