Results 1 to 5 of 5
Thread: Cowl Seal 812784 needed
02-01-2023, 09:14 AM #1Junior Member
- Feb 2021
- Dandridge TN
I'm looking for a new cowl seal or a very good used one for my 1990 Mercury V6 150
02-01-2023, 01:11 PM #26000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
Cowl Seal Source
There's nothing mysterious about a Merc cowl seal. it's a glorified version of automotive trunk seal stock. If you can get the dimensions of the bulb or finger lip and the cross section of your old seal, simply match the patterns and buy 20 ft of roll stock. If your old seal was stapled, pull the staples, match length to new stock and install new seal with automotive sealant. Merc used staples rather than adhesives that need time to dry and set.
02-01-2023, 03:03 PM #3Junior Member
- Feb 2021
- Dandridge TN
I haven't removed it yet because I been looking try to find a seal similar but haven't had any luck. The current seal has a couple of bad kink/pinch points in it from the cowl not being reinstalled properly prior to me getting it. I'm ready for paint now so I thought I would give it a shot on here. I didn't want to remove old prior because it will not go back on well at all. I figured the old damaged seal was better than not seal. Maybe someone has source they used for theirs. I appreciate the suggestion and quick response.
02-02-2023, 09:28 AM #46000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
Pinch Points
Put the cowling under the sun for a while and see of the seal will soften enough to remove the creases. Also try a heat gun but be careful with how much heat you apply. If it is a bulb seal you can "stuff it" with a foam core and talcum powder makes stuffing easier to do.
02-03-2023, 01:15 AM #5Junior Member
- Feb 2021
- Dandridge TN
Tried heat gun and even clapped a couple of pcs of aluminum on each side to flatten it out and I'll let it sit over night. It not looking like it going to do a lot because it really harden from age. Sun not an option right now because it cold and rainy here in TN. It's not a bulb type seal. Thanks again
70 OMC cowl seal needed?
By 87vantage in forum Parts WantedReplies: 0Last Post: 03-22-2016, 01:12 PM -
WTB OMC cowl seal
By upyours in forum Misc. Parts and AccessoriesReplies: 1Last Post: 08-25-2014, 01:13 PM -
Mercury Tech: Propshaft seal #s needed
By Damyankee in forum Technical DiscussionReplies: 0Last Post: 09-14-2010, 03:08 PM
