Results 1 to 15 of 24
01-24-2023, 12:41 PM #1Team Member
- Lake Coochiching, Ontario
- 7,758
- 272
- 485
- 1577
- 6 Post(s)
Did OMC have "pressure backed piston rings"?
I think I remember pressure backed piston rings in old Johnson and Evinrude brochures, but of course I could be wrong.
There is an article about piston rings in this months Hemmings Muscle Machines magazine. It discusses horizontal and vertical gas ports that allow the combustion pressure to help seal the ring to the piston wall. The article reminded me of what I may remember about old advertising.
GAS PORTED RINGS (totalseal.com)
5 Reasons Why Gas Ported Piston Rings Make a Massive Difference (lsxmag.com)
Hemmings | Hemmings
01-24-2023, 03:16 PM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
yes
01-24-2023, 03:28 PM #3Team Member
- 7,758
- 272
- 485
- 1577
- 6 Post(s)
Did the pressure backed piston rings work well? Were they cost effective?
01-24-2023, 04:06 PM #4Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
I think they worked well until the piston to wall clearance wore to the state that the ring could slip out of the groove. These were on the old Crossflow motors. They started out with lots of clearance and only got more. I do think they worked well, Chris.
Baker343 liked this post
01-24-2023, 05:44 PM #56000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
A Word About Tolerances
Tight tolerances and fit do not come cheap. Lots of "clearance" comes from the economic decision to accept component tolerances at some boundary but also the labor and cost effort associated with component assembly. Want tighter tolerances? Prepare to pay for it.
Honda used to make engines with custom crankshaft bearing shell sets to absorb the machining variability of each crankshaft during block assembly. Outboard engine companies are no different in their design objectives.
01-24-2023, 09:53 PM #6Member
- Sep 2021
- New Richmond, Ohio
- 91
- 27
yes they did use them
01-25-2023, 02:34 AM #7Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
OMC slugggs of the era were big an bulkie..... the pressure back were triangle in cross section.......the wedge shape put some /tooo much load on the piston land.... the early ones were high location..... not enughf ring land.....which broke...... later ones had the rings lowered.......from what I remmmmbure..........
01-25-2023, 06:38 AM #8
I think you’re talking about “semi dykes” rings.
Tons of companies did this, including bikes.
As a fan of ring sealing, I like the theory.
But, as stated, increased sealing = increased friction.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
David - WI liked this post
01-25-2023, 10:08 AM #9
The High ring pressure back were only in 1978/79 crossflows, carbon built up on the back side also causing ring jacking.
Instigator liked this post
01-25-2023, 11:03 AM #10
If I remember correctly it was low octane fuel that beat the high/pressure back ring lands out...didn't know about the carbon buildup doing damage. Was told to use premium and good oil.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Ranger 17' Aztec / Merc 115
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
01-25-2023, 08:59 PM #11Member
- Sep 2021
- 91
- 27
yes bad gas omc was giving pistons rings gasket to most anyone who had trouble i know i rebuild a lot of motors for them free parts sometimes even a new block but the new pistons were heavy and on a 150 v6 you would lose about 500 rpm but some of the motors i bilt were still running 15 to 20 years later
rgsauger liked this post
01-25-2023, 11:13 PM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
KNew I'd posted these homemade pressure backed piston
https://www.screamandfly.com/showthr...hrysler+RacingLast edited by FMP; 01-26-2023 at 04:51 PM. Reason: K
01-30-2023, 12:39 AM #13
Anyone have pictures? All of my old crossflows have high ring pistons. The rings are different from loopers as they have a bevel to collect compression to increase ring tension.
That is the way I saw it anyway. I collected every high ring piston I could find for my 2.6L Xflows. And had them all machined with the XP skirt cut. I smoked a couple pistons and learned... you need spares!
01-30-2023, 10:23 AM #14
78-79
01-31-2023, 04:58 PM #15Member
- May 2008
- wichita,ks
- 65
- 10
- 18
It's called gas porting, ok on a race engine, but on a 2 cycle it tends to carbon up fast...whether it's top, side or ring ported. I imagine it was an economical alternative to more precise piston to wall clearance.
Do rings "seat" after new piston is installed? Will compression change?
By CircleHook in forum Technical DiscussionReplies: 27Last Post: 06-13-2015, 08:02 AM -
"High Pressure" power trim pump for Mercury 1400 and 1500?
By number21 in forum Technical DiscussionReplies: 1Last Post: 08-20-2013, 07:08 PM -
piston rings (pressure back or non pressure back)
By madatnumbers2 in forum Technical DiscussionReplies: 0Last Post: 06-14-2013, 01:39 PM -
Trim Pump "O" rings
By Electric Fish in forum Technical DiscussionReplies: 14Last Post: 09-02-2003, 10:01 AM
