Results 1 to 4 of 4
Thread: Yamaha F50/F60 difference.
01-13-2023, 03:08 PM #1
Okay, question for the Yammy techs. I watched a youtube vid of a guy that takes the air intake apart on his F50. Inside of the single round intake hole is a disk that is nothing but a air restrictor that decreases the opening. He removed it and said there was a noticeable difference in the performance. Could this be the only difference between a 50 and a 60? Also, would the map sensor on the fuel injection automatically adjust for any difference in the airflow?
1970 15' Allison/135 Chrysler stacker
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
01-18-2023, 01:41 AM #2
Would like to know too for the carb version, there is a 70hpnas well. Is it the camshaft ?
Last corner in Flosta boat race 90mph.
http://www.youtube.com/watch?v=WbqlgOB3ulQ
Espen Hilde
Hosle Norway
Mobile:
+47 90700200
01-22-2023, 09:36 AM #3
If I am correct, the 70 has a bit more compression, different ports and cam as well as throttle being a touch different. Basically the head is different.
I had the specs on the carb motors but not on this computer, although I think all the service manuals are on here if a rummage deeper into them.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
02-02-2023, 11:36 AM #4
The yamaha 50 and 60's are real similar to the Mercury 4 cylinder 40/50/60 with a two valve head. As in, you can bolt the Yamaha head to the Mercury block. The 70 Yamaha departs from the other two by having a 4 valve head. Picture is of a merc 40-60 head next to a yamaha 70 head
Yamaha 70 lower unit difference?
By Fishbum in forum Technical DiscussionReplies: 0Last Post: 04-28-2020, 03:41 PM -
Yamaha 85 and 90 difference ?
By Michael B in forum Technical DiscussionReplies: 18Last Post: 02-14-2009, 05:16 AM -
Yamaha drag Merc ET difference ??
By inspectorlance in forum Props, Setup, and RiggingReplies: 9Last Post: 02-03-2008, 03:21 AM -
1994 150 200 yamaha difference
By lulu2 in forum Technical DiscussionReplies: 6Last Post: 11-20-2006, 07:22 PM -
difference between Yamaha 150 Saltwater Series EFI vs Carborated 150
By george7 in forum Technical DiscussionReplies: 4Last Post: 07-22-2001, 10:21 PM
