Results 1 to 12 of 12
    Aug 2021
    Osteen/Deltona, FL
    Mid Section exhaust reliefs
    I have some question about the reliefs on different mids. I searched but didn't really find any conclusive information.
    Where they different vs years? Example below of my 1993 where it has the rubber boot. I have another one that has the two cast in slots open and being used.
    83 Vking 150 Mariner 2.5L
    Jun 2009
    Bristol, Connecticut
    Basically before 91 you have the open slots/no rubber boot
    They are more loud and used on the 80s black max split shell cowls
    2.0 2.4
    And then in the early 90s-2000 when they made the 2.0 and 2.5,
    They used a drop on cowl, with the rubber boot integrated into the lower half of the cowl/skirts
    It's not as loud as the 80s version
    Few of my engines use the older style mid section housing and a drop on cowl, I cut the skirts short so the holes can breathe
  3. Thanks VkingMike thanked for this post
    Likes VkingMike, David - WI liked this post
    Sep 2021
    New Richmond, Ohio
    my 1989 135 had a drop on cowl
  5. Likes Aaronhl liked this post
    Jun 2009
    Quote Originally Posted by James45157 View Post
    So i am not sure when exactly the conversion was it could have been in 89/90 around the same time they made the 2.4 200 with the drop on cowl before the 2.5 200...Yours could have been an 89 with drop on cowl from the factory or replacement??
  7. Likes David - WI liked this post
    TX......somewhere?
    cowl change for all came in '89.. was time for a change plus they had ta make room for tha 40 amp pos water cooled stuff..
    Mar 2020
    netherlands
    Is it possible to cut open the blocked slots? Or did they change something also behind the slots?
  10. Likes ssv1761982 liked this post
  11. #7
    Feb 2011
    HUDSON, FLORIDA
    If you look in the mid, pwr hd off, there not really blocked, the casting has a anti reversion baffle built in.
  12. #8
    Mar 2020
    netherlands
    Quote Originally Posted by KIRCHNER View Post
    a WHAT??
  13. #9
    Jun 2009
    OK Took some pics to try to show the details of each of the two style mid section housings
  14. Likes Baker343 liked this post
  15. #10
    Mar 2020
    netherlands
    Quote Originally Posted by Aaronhl View Post
    [/FONT][/COLOR]
    So you can cut them open and drill a hole in de wall behind it. Right?
  16. #11
    Jun 2009
    I have seen engines on the river runs that have been drilled out, seems like you might need to slot the wall behind the port side too if you want it to be as close to the oem slotted mid section as possible. See how the oem slots are upwards, u might need to measure to see if drilling holes straight in would go through to the cavity
    Plainville, CT
    I have a 1988 with the slots and the clam shell cover, and also a 1994 with the rubber boot and the drop on cover. I like the clamshell because it's easier to work on to get at things easily, but I like how quiet the 1994 is.
  18. Likes David - WI liked this post
  1. Mercury Tech: Old Merc Laser 220 noisy all of a sudden (exhaust reliefs?)
    By gmacrae in forum Technical Discussion
    Last Post: 07-11-2014, 11:25 PM
  2. 250 mercury med section exhaust
    By shesha in forum Technical Discussion
    Last Post: 07-13-2010, 04:50 AM
  3. plugging exhaust reliefs...?
    By YukonGt in forum Technical Discussion
    Last Post: 11-12-2003, 01:32 PM
  4. Mid section exhaust question
    By Stoker100 in forum Technical Discussion
    Last Post: 06-02-2003, 08:59 AM
