Results 1 to 12 of 12
Thread: Mid Section exhaust reliefs
01-13-2023, 09:14 AM #1
01-13-2023, 10:58 AM #2
Basically before 91 you have the open slots/no rubber boot
They are more loud and used on the 80s black max split shell cowls
2.0 2.4
And then in the early 90s-2000 when they made the 2.0 and 2.5,
They used a drop on cowl, with the rubber boot integrated into the lower half of the cowl/skirts
It's not as loud as the 80s version
Few of my engines use the older style mid section housing and a drop on cowl, I cut the skirts short so the holes can breathe
VkingMike thanked for this postVkingMike, David - WI liked this post
01-13-2023, 10:57 PM #3Member
- Sep 2021
- New Richmond, Ohio
- 91
- 27
my 1989 135 had a drop on cowl
Aaronhl liked this post
01-13-2023, 11:02 PM #4
01-14-2023, 04:40 AM #5
cowl change for all came in '89.. was time for a change plus they had ta make room for tha 40 amp pos water cooled stuff..
01-29-2023, 05:57 PM #65000 RPM
- Mar 2020
- netherlands
- 163
- 14
Is it possible to cut open the blocked slots? Or did they change something also behind the slots?
ssv1761982 liked this post
02-03-2023, 04:44 PM #76000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
If you look in the mid, pwr hd off, there not really blocked, the casting has a anti reversion baffle built in.
02-05-2023, 12:55 PM #85000 RPM
- Mar 2020
- netherlands
- 163
- 14
02-05-2023, 08:51 PM #9
OK Took some pics to try to show the details of each of the two style mid section housings
Baker343 liked this post
02-06-2023, 03:10 AM #105000 RPM
- Mar 2020
- netherlands
- 163
- 14
02-06-2023, 10:41 AM #11
I have seen engines on the river runs that have been drilled out, seems like you might need to slot the wall behind the port side too if you want it to be as close to the oem slotted mid section as possible. See how the oem slots are upwards, u might need to measure to see if drilling holes straight in would go through to the cavity
02-06-2023, 10:18 PM #125000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I have a 1988 with the slots and the clam shell cover, and also a 1994 with the rubber boot and the drop on cover. I like the clamshell because it's easier to work on to get at things easily, but I like how quiet the 1994 is.
Mercury Tech: Old Merc Laser 220 noisy all of a sudden (exhaust reliefs?)
By gmacrae in forum Technical DiscussionReplies: 7Last Post: 07-11-2014, 11:25 PM -
250 mercury med section exhaust
By shesha in forum Technical DiscussionReplies: 4Last Post: 07-13-2010, 04:50 AM -
plugging exhaust reliefs...?
By YukonGt in forum Technical DiscussionReplies: 2Last Post: 11-12-2003, 01:32 PM -
Mid section exhaust question
By Stoker100 in forum Technical DiscussionReplies: 23Last Post: 06-02-2003, 08:59 AM
