Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: 1983 vector
    Sep 2021
    South Louisiana
    1983 vector
    Got the boat in July of 2021 and started gutting to rebuild. Built a jig to set it on and started cutting out transom, old core, stringer box and foam boxes and ground entire hull down with a brazed cup wheel and 36grit wheels on a 4 inch grinder. For transom replacement i used 3 half inch thick pieces of marine plywood bonded together with a wet layer of csm. Then put in a layer of 1808 where transom will fit then bonded the new transom in with a layer of csm. Covered that with 3 layers of 1808. Was going to delete the splashwell but being i kept the piece i cut out i decided to put it back in for its functionality. Once that was done i laid a layer of 1808 threw out the hull. Now im putting 1/2 inch balsa core in, started up in the wings and then did the pad. Bonded everything in with 2 wet layers of csm and covered with 1808. Thats where im at now, hopefully i can get the rest of the core in soon!
    Attached Thumbnails Attached Thumbnails 0FC35177-1D87-4CA0-9BB9-FEF7892FBAD9.jpg   4EF51149-0B0E-42B7-98A3-B00FBA70C2BB.jpg   8C1511D4-9C6F-4607-AB1B-F6E308CB6500.jpg   969F715C-F2A1-4DA8-A033-7A17B27C06B3.jpg   04F40F7B-6D87-4E99-A795-1BF9BD0366C6.jpg
    86030140-DF04-42C9-A298-4C930CB464F9.jpg   BE47E5C5-45F3-4D20-B442-E1F21960E037.jpg   A3A6EE8A-FD12-4EE4-B6E6-E4C1EE0A8B66.jpg   81576E58-1B1A-4DCD-A2C0-972C6FC4B628.jpg   A9B4B9B5-3039-40BA-9604-900E172E2560.jpg
    DE4CF671-BA0C-407A-A9F9-32ACBF9F8057.jpg   E5EBA2D5-7A47-4F81-8C8B-D2F99B6021CE.jpg   6A8C0B7F-3CFD-4BC2-9E3A-D3F1844698A0.jpg   8A40EF0C-7158-4F23-9D4D-4860190C90DF.jpg   4A317DEF-5F84-4A9E-8012-F77AB3A507B4.jpg
    2B61195F-B3EB-4CFE-9F8E-52D060831736.jpg   159F5742-1ABA-4C6F-A425-556AB5B9ABD0.jpg   4272342A-A6A0-405D-99BF-C355A7F558B2.png   5051F60F-5225-4DA1-8666-5197F6B2E717.jpg   992F7091-5673-4C69-83A0-B3F887E46B4F.jpg
    41CE95A9-A7D1-4250-AFC2-A7F27AE1F38A.jpg   9CE774A0-F6FF-4084-B865-A55FB75DCE4B.jpg   CF3268B9-030C-43A8-808C-A8F614FE814C.jpg
  2. Likes VkingMike, LakeFever, doug7488, OnPad liked this post
    Good stuff! Be very strong and will fly right. Nice neat glass work.
  4. Likes VkingMike liked this post
  5. #3
    Sep 2021
    South Louisiana
    Thanks! Hope she flys and is safe.
    Aug 2021
    Osteen/Deltona, FL
    Awesome work, keep posting pics. We love these build threads
    83 Vking 150 Mariner 2.5L
  7. Likes rgsauger liked this post
    Mar 2004
    Brooklyn Park, MN
    looking good, nice and clean glass work.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Mar 2004
    Brooklyn Park, MN
    did you connect the top cap stringers to the top of the transom? circled in red, if you did not cut some plywood that fits in there and glass it up and put it in there from the inside. That is an oversight the factor never connected the top cap stringers to the hull transom top.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Sep 2021
    South Louisiana
    Thanks fellas, debating weather i should put stringers in now then put the core on the outside of them or do the core first then bed the stringers in. I was worried without the stringers there the core may want to slide down some once i bed it in and put some wait on top of it.
    Sep 2021
    South Louisiana
    So for that area rj, i wetted out a piece of 1.5 oz on a flat table with clear wrap on it the. When that hardened i cut out pieces to fit in that gap and classed from both sides, then went from the back and tied in what i cut out in the wood with new wood bonding it to the transom and existing wood under there. Only thing i want to do is cut out another piece of 1/2 inch about 6 or 8 inches longer then the patch and laminate it over that
    Mar 2004
    Brooklyn Park, MN
    It helps a lot connecting the cap stringers to the top corners of the transom. I would go stingers first as your not bagging the core down, it may slide like you said.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2018
    Floating around
    Nice!
  14. #11
    Sep 2021
    South Louisiana
    I was gunna mix up some resin and milled fibers into a paste to bed stringers in. Is there a better way to do it then that?
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by BrononC View Post
    may have to put some cabosil in also to make it thicker, or saw dust or some sort of filler if the milled fibers do not thicken it enough. But that's what I did. Bed them in and then once that starts to kick put 1808 over that fillet and it is strong!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. #13
    Sep 2021
    South Louisiana
    Sounds good yeah i have cabosil also
  17. #14
    Dec 2001
    Me thinks this guy likes his boat......... Nice job.
  18. Likes BrononC liked this post
  19. #15
    Pekin, IL
    Project looks great. Those things are a blast to drive.
    Rock
    Team Junk
  1. 1983 Vector
    By scottmcbx in forum Fiberglass and Composites Discussion
    Last Post: 01-23-2015, 12:35 AM
  2. 1983 Vector pad
    By scottmcbx in forum Technical Discussion
    Last Post: 09-02-2014, 11:07 AM
  3. 1983 Hydrostream Vector
    Last Post: 09-02-2014, 10:56 AM
  4. 1983 Vector I buffed on/ before and after
    By zzzman in forum Fiberglass and Composites Discussion
    Last Post: 04-29-2006, 04:31 PM
