Results 1 to 15 of 26
Thread: Back at 200...
01-08-2023, 06:50 PM #1Member
- Jan 2018
- Anderson, SC
- 43
- 39
- 16
- 11
Back at 200...
Well it's been a while since I touched the boat and motor. Life has it's twists and turns, some good and some bad, unexpected and unjustified.
I took the lower off the 200 (https://www.screamandfly.com/showthr...11#post3359011) and the 150. Once I get the longer studs out of the 200 mid I should be able to install the 150 lower but have a few questions:
The 150 drive shaft will spin clockwise, in forward gear the prop shaft spins clockwise.The 200 drive shaft spins counter clockwise and in forward gear the prop shaft spins clockwise.
Why would it do that?
I REALLY want to use the 200 lower because if the nosecone, the 150 lower I guess will work if I have to use it. How hard is it to swap the guts, or leave it to the pros?
01-08-2023, 06:55 PM #2Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 307
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
rgsauger liked this post
01-08-2023, 07:12 PM #3Member
- Jan 2018
- Anderson, SC
- 43
- 39
- 16
- 11
That's what I was thinking, but I have very limited experience with all this. I did a little googling before I posted just to see if there is an easy answer, from what I've read yes it is for a twin set-up. The previous owner never mentioned it was part of a twin set-up he said it was a single until he found the Yamaha he was looking for.
All the pictures of the engine he sent me were a single set-up.
Does the 200 counter clockwise lower render it "useless" for my 20ft NITRO?
01-08-2023, 07:23 PM #4Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 307
- 6 Post(s)
If in fact it is a reverse rotation gearbox, you could get a reverse rotation prop for it. That would be quick and dirty. Although if you were wanting to get really fancy with props, you might have a smaller selection or a bigger $$$ to deal with.
Wildcard: I think I have read on here that the reverse rotation gear setups are hard to find and in demand. If so, you might be able to sell the gearset and buy the right ones. That would require a re install and setup of the new gear set. BUT reading back you old thread, this would ALSO be your chance to swap in a 20" drive shaft as well. So the idea of swapping out gearsets might be more appealing...
-PeterLast edited by pcrussell50; 01-08-2023 at 07:25 PM.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
01-08-2023, 07:34 PM #5Member
- Jan 2018
- Anderson, SC
- 43
- 39
- 16
- 11
I don't want to do the reverse prop, remember Peter I'm still new at all this . I assume 80% of the props out there for sale are for normal rotation, I don't even know where to start with a prop for this boat nor do I have one.....
Well I'm going to sell the 5" spacer and the rest of the stuff I have no use for, so it might work out. Problem again is I don't have any idea of value or what I "actually" have.
01-10-2023, 01:12 PM #6Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 307
- 6 Post(s)
Originally Posted by thesignguy;[URL="tel:3374282"
As to your reverse rotation gear box, you should be able to disassemble it yourself without too much trouble, even if you might want a pro to put it back together again. so you can add your long shaft and reverse gears to your “sell” pile.
you might try to offer the reverse gears here at S&F simply because I recall someone asking about them not so long ago and not having much luck.
keep the reports coming. As a fellow “just got a 2.4/200” bro with you, you’re story is interesting to me ;-)
-PeterLast edited by pcrussell50; 01-10-2023 at 01:15 PM.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
thesignguy thanked for this post
01-11-2023, 06:09 PM #7
01-11-2023, 07:42 PM #8Member
- Jan 2018
- Anderson, SC
- 43
- 39
- 16
- 11
01-11-2023, 07:53 PM #9
Thats strange because even a counter lower will have a clockwise driveshaft, it's the gears that change direction to the prop shaft. See if you can get it into another gear while you turn the drive or prop shaft, seems like it might be worth while opening it up atleast take the water pump off if you havent already because the driveshafts freely spin both ways
01-11-2023, 08:14 PM #10
Does it make any difference if it's a ratcheting gearcase or not?
01-11-2023, 08:21 PM #11Member
- Jan 2018
- Anderson, SC
- 43
- 39
- 16
- 11
The 150 lower I pulled will only free spin the driveshaft clockwise, it "locks" and will not spin CC in any gear. The 200 shifts fine, forward, neutral and reverse no problem even while spinning the driveshaft.
I'll pull the pumps off both and see what I can see.
Aaronhl liked this post
01-11-2023, 08:48 PM #12Member
- Jan 2018
- Anderson, SC
- 43
- 39
- 16
- 11
01-11-2023, 08:52 PM #13
thesignguy liked this post
01-11-2023, 08:53 PM #14
Lets clarify a few terms. You are spinning the driveshaft with your hands clockwise?
On the shifter,, are you turning the shift shaft with a tool or channel locks? Fully clockwise will engage and spin the prop shaft clockwise on both rotation gearcases. On a counter rotating gearcase forward is engaged by turning shift shaft counterclockwise. Said another way a counter is using the aft gear, the original reverse configuration as Forward.
You say the driveshaft seems to lock when you try to spin it counterclock wise. The water pump impeller can make it feel that way. It does not like to be rotated backwards and will resist. Pulling the pumps off will allow turning driveshaft without tension of impeller.
A gearcase may be ratcheting or not depending on year , model ect. This is referring to spinning the prop shaft and how the clutch dog on prop shaft engages the gear. Early cases ratchet. Said another way is to say it will coast or spin freely when engine dies. When you spin it by hand it will only lock in one direction. A non ratcheting gearcase will lock in both directions.
I hope this is helpful.Jim
thesignguy thanked for this postDavid - WI liked this post
01-11-2023, 08:54 PM #15
check to make sure you are actually in the right gear
Use a 11/32 I believe socket to shift gears so you dont damage the splines, spin the propshaft to complete the shift
I did some tests of my lower unit it's a early 90s ratchet, can use on 135-200hp
FORWARD
driveshaft spins same way as propshaft
driveshaft spins clockwise, propshaft spins clockwise
propshaft spins clockwise, ratchet sound, driveshaft does not spin
can spin driveshaft or propshaft counter clockwise freely, they spin with each other
NEUTRAL
both driveshaft and propshaft move freely, independently
REVERSE
driveshaft spins opposite way as propshaft
driveshaft spins clockwise, propshaft spins counter clockwise
can spin driveshaft or propshaft counter clockwise freely, they spin opposite of each other
My boat plains then sinks back down. Hooked back I think. What to do?
By Racer71 in forum Jet Boats, V-Drives and Stern DrivesReplies: 8Last Post: 08-06-2009, 04:36 PM -
Let's step back in time... Back to 1991
By Scream And Fly in forum General Boating DiscussionReplies: 19Last Post: 02-21-2008, 12:07 AM -
Since draggin' the George W post back up the board got us back on politics...........
By Raceman in forum General Boating DiscussionReplies: 80Last Post: 02-06-2003, 09:38 AM
