Results 1 to 6 of 6
Thread: merc i.d. location
01-06-2023, 09:01 PM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
merc i.d. location
where would i find serial # on a 300 two stroke
01-10-2023, 12:04 PM #2
ill take a stab since it's been a few days without a reply, i have a 225 96 3.0 the serial # is on the bottom of the block on the starboard side, the lower cowl was in the way so I didn't really see if until i took that off
KIRCHNER thanked for this post
01-10-2023, 03:53 PM #36000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Not on the port side, up top?
01-10-2023, 04:28 PM #4
So im not really in the 300hp club yet only messing with the older 2.5s, 225 3.0 - I thought maybe the welsh plug popped out because there is a hole on the upper port side, popped out like some of the serial numbers do, but i happen to find the actual welsh stamped on the lower starboard side - again this is a 1996 3.0 litre 225 maybe similar block to the 300 u have??
And hopefully by now you dont use the mid section serial number for the powerhead serial number, it could be a good comparison as mids can interchange but best to find the powerhead serial
01-10-2023, 04:29 PM #5
OnPad liked this post
01-10-2023, 06:45 PM #6
Merc 250 3L dual pyro sensor location
By rvaha in forum Technical DiscussionReplies: 6Last Post: 06-13-2013, 04:07 PM -
Merc Diverters Material & Location??
By MrCougar in forum Technical DiscussionReplies: 13Last Post: 03-16-2007, 11:36 PM -
Steering hole location for Merc 200
By Mach2 in forum Technical DiscussionReplies: 7Last Post: 06-12-2002, 09:02 AM
