Results 1 to 6 of 6
    Feb 2011
    HUDSON, FLORIDA
    merc i.d. location
    where would i find serial # on a 300 two stroke
    Jun 2009
    Bristol, Connecticut
    ill take a stab since it's been a few days without a reply, i have a 225 96 3.0 the serial # is on the bottom of the block on the starboard side, the lower cowl was in the way so I didn't really see if until i took that off
  3. Thanks KIRCHNER thanked for this post
    Feb 2011
    HUDSON, FLORIDA
    Not on the port side, up top?
    Jun 2009
    Quote Originally Posted by KIRCHNER View Post
    So im not really in the 300hp club yet only messing with the older 2.5s, 225 3.0 - I thought maybe the welsh plug popped out because there is a hole on the upper port side, popped out like some of the serial numbers do, but i happen to find the actual welsh stamped on the lower starboard side - again this is a 1996 3.0 litre 225 maybe similar block to the 300 u have??
    And hopefully by now you dont use the mid section serial number for the powerhead serial number, it could be a good comparison as mids can interchange but best to find the powerhead serial
    Jun 2009
  7. Likes OnPad liked this post
    Mar 2022
    Lake Travis Texas
    Early 2.4 and 2.5's had serial plug on top. Replacement powerheads have no serial numbers.
    Jim
  9. Likes Aaronhl, OnPad liked this post
  1. Merc 250 3L dual pyro sensor location
    By rvaha in forum Technical Discussion
    Last Post: 06-13-2013, 04:07 PM
  2. Merc Diverters Material & Location??
    By MrCougar in forum Technical Discussion
    Last Post: 03-16-2007, 11:36 PM
  3. Steering hole location for Merc 200
    By Mach2 in forum Technical Discussion
    Last Post: 06-12-2002, 09:02 AM
