Results 16 to 30 of 33
Thread: Power Valve
01-05-2023, 10:52 AM #16
I had a 1974 Maico 400 radial when I was a kid. Start in first, second, it didn't matter.
Torque from idle till it wouldn't rev any higher. If it fell off the curve .. I didn't really notice it and probably should have shifted already. Plenty of over-rev to it's total design of, carb, case volume, cylinder and pipe.
Most pipe builders get pushed into a corner (myself included) of building (more HP) as R+D continues .. until the acoustics outrun the useful airflow of the rest of the package, and are then dubbed as being dud's.
Gordon Jennings wrote a book on two-stroke tuning. There was a second volume on just expansion chambers. Plenty of information on what builds low end torque in his writings.
Variable exhaust timing was a great idea. Some stuck with the use of dirtier oils, but synthetics were accepted practice by then.
Wayne Taylor had the right idea.
01-05-2023, 11:52 AM #175000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
01-05-2023, 12:09 PM #185000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
01-06-2023, 02:42 PM #195000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
01-06-2023, 07:03 PM #20
The 2 stroke boat engines have the cylinders turned so the exhaust port is not 90 degrees from the crank.
powerabout liked this post
01-06-2023, 07:31 PM #21
The g2 is 90deg the cylinders are not canted down, I have a 3.4 block some day we will see what it will do. kinda hard to make an adapter with the exhaust on the left of both banks but it will go on the stv some day..
01-06-2023, 07:39 PM #22
small g2 powervalve set up.. they were on track but brp did what they do best.
01-07-2023, 12:51 AM #23Member
- May 2008
- wichita,ks
- 65
- 10
- 18
Expansion chambers do not kill the bottom end.
01-09-2023, 07:35 PM #24
Expansion chambers are built to specific power bands. If you build the pipe for a top end port map you will loose some bottom end and vice versa for a low port timing motor and pipe. They make more power than an exhaust chest design but they will narrow the power band some. Boats do not have the ability to shift gears therefore in “normal boating conditions” an exhaust chest provides a better overall power band as it uses the other cylinders to scavenge the exhaust/ draw in the intake and pulse to stuff the extra fuel/air back in to the cylinders.
01-09-2023, 08:27 PM #25Member
- May 2008
- wichita,ks
- 65
- 10
- 18
A so so expansion chamber is going to make more power than the chest the OEM's use. The problem is where are you going to mount/route the chambers, Rec boaters aren't going to want pipes outside the cowl/mid. A dedicated slippy pipe per cylinder with water injection would be awesome.
John S liked this post
01-09-2023, 08:35 PM #26
I was looking for the pictures of the one Wayne was working on, he was one of a kind.
01-10-2023, 08:21 PM #27Member
- May 2008
- wichita,ks
- 65
- 10
- 18
01-10-2023, 08:23 PM #28Member
- May 2008
- wichita,ks
- 65
- 10
- 18
01-21-2023, 10:16 AM #295000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I wonder if making the tuner variable would be an easier/simpler modification and still give you most of the gain?
01-21-2023, 10:51 AM #30
Last I heard, it was still in Wayne Taylor's shop. I know the twins were offered pretty good money for it .. but they weren't interested in selling it ...
From what I remember, it's a 2.6L
Glastron1987
An oldie, but goodie ...
http://www.bridgestonemotorcycle.com...ou_really6.pdf
Glastron1987 thanked for this postGlastron1987 liked this post
Power Trim Unit for 1978-1979 Mercury Tower of Power
By 1975ss14 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-05-2018, 01:40 PM -
WTB merc thermal valve #814612 - brass valve/fitting that screws into middle of head
By CircleHook in forum Parts WantedReplies: 2Last Post: 03-17-2016, 06:05 AM -
OMC Tech: V8 Dual Power Packs to Single Power Pack, what's needed?
By kimswang in forum Technical DiscussionReplies: 8Last Post: 11-09-2014, 02:09 PM -
Poppet valve/relief valve issues 1978 2.4l Merc
By rujr in forum Technical DiscussionReplies: 2Last Post: 06-24-2013, 08:21 PM
