Results 1 to 4 of 4
    Apr 2020
    Australia
    Optimax flywheel dampener
    I’ve got a 2010 mercury 250 pro xs, motor is healthy but still lacks some torque on the initial hit out of the hole when pulling heavy skiers. Has anyone removed the flywheel dampener on there 250/300xs to reduce the mass on the flywheel? Is it an easy DIY mod instead of full lightweight flywheel replacement? Or risk causing damage to the crank?
    Just chasing some tricks in conjunction with prop/set up to give it a stronger holeshot.
    thank you
    PARADISE /Naples
    Ski prop
    I have three of those motors but they were the last year of the high compression version, so they have more low end power, they need higher octane.
    Also said to make 270 some HP.
    Apr 2020
    Australia
    Quote Originally Posted by CUDA View Post
    Ski prop
    just found one of the reeds had broken and was sitting in the reed cage so hopefully that is the problem
    PARADISE /Naples
    There you go.
  1. Looking for a 90 or 115 optimax flywheel
    By JPEROG in forum Parts Wanted
    Last Post: 08-30-2017, 06:24 AM
  2. 3.0l Optimax lightened flywheel
    By 2jz in forum Misc. Parts and Accessories
    Last Post: 12-07-2014, 10:58 AM
  3. optimax's flywheel
    By kostas74 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-17-2010, 07:30 AM
  4. Mercury Tech: Steering pivot dampener bolt corrosion
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 11-24-2008, 10:19 AM
