Results 1 to 12 of 12
12-07-2022, 08:26 PM #1Junior Member
- Dec 2022
- Havana FL
- 12
Yamaha - 85 - Pitting on Crank -- Too much or nothing to worry about.
Good evening,
I've been reading the forums for years and need some input.
Cranks - cheap new crank vs OEM used.
I chose OEM used, and bought one with slight pitting on a journal. Its going into a yamaha 85 s stroke. I'll use it for regular boating, nothing too fast. Do you think this little bit of pitting is ok? I thought so because I bought the crank but would like your input. As long as there are no high spots I should be good? Also any ideas on how to level it out? I would love some input.
Thanks guys,
HavanaLast edited by Havana; 12-07-2022 at 08:37 PM.
12-07-2022, 09:38 PM #2
Not in my world.
David - WI, ssv1761982 liked this post
12-08-2022, 01:44 AM #3
Welcome to the forum! Can you post a picture?
OnPad liked this post
12-08-2022, 06:22 AM #4Junior Member
- Dec 2022
- Havana FL
- 12
12-08-2022, 06:56 AM #5
Yeah, that’s not pitting. More like “gouges”, “pock marks”, etc… looks like something for the junk pile to me.
Unless, of course, you can find someone who knows what they’re doing to weld it up with the right material and machine it to spec again.
David - WI liked this post
12-08-2022, 07:11 AM #6Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
doorstop
12-08-2022, 10:25 PM #7Junior Member
- Dec 2022
- Havana FL
- 12
12-09-2022, 01:23 AM #8
12-09-2022, 07:49 AM #9Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
It's not the same journal,it's the metal underneath the same journal,just sanded down past the chattermarks in the surface of the journal.Aside from most likely not being round,the hard shell surface that was failing is now gone,leaving a much softer inner metal that wont hold up to the wear requirements.This is the reason these cranks aren't reground and fitted with oversized bearings like most automotive cranks that ride on an oil film on insert bearings...
Anyway,Mercury,many years ago published allowable specs for polishing...3 tenths.Not tenths of an inch,or milimeter,but of a thousandth of an inch...around a third of a thousandth,small enough that most folks aren't equipped to measure.
I've relaxed a bit on that,and while race cranks need to be spot-on,I'll polish up to half a thousandth on a fishing motor to achieve a perfect surface.
I'm guessing the OP's crank is 15-20 thou undersize now...occasionally I buy one off the net that has had the same treatment...always measure,Chris
12-09-2022, 11:19 PM #10Junior Member
- Dec 2022
- Havana FL
- 12
Thanks, I used the shoelace method so it is generally round. It wont fly but for fishing I think it will work. I'll go heavy on the oil and I'll let you know in a year how its going.
12-09-2022, 11:44 PM #11Junior Member
- Dec 2022
- Havana FL
- 12
I didn't know that about the surface metal versus the internal metal. I'm always learning , thanks for the info. I would also imagine its even tough to get good , new cranks with all the junk floating around from China. High tin content, weak underneath. My plan for this motor is to putt up the river in this one and take my kids fishing, its going on a pontoon. Heavy on the oil, light on the throttle... right?
12-10-2022, 05:46 AM #12
The crank had spalling... it most likely was rusty at one time. It normally starts as pits from rust at the contact points of the needle bearings and journal then progresses into what you had and gets worse until it slings a rod out the side. Cranks with Some small cleaned up pits that are not all the way across the journal on the back side may last but on the thrust face like yours usually never last. Yours was WAY beyond clean up, it has to look like an egg and it will destroy itself in no time. JMHO
250 sho cylinder pitting
By mccutch2u in forum Technical DiscussionReplies: 4Last Post: 07-25-2021, 10:45 AM -
drive shaft pitting
By nelson edens in forum Technical DiscussionReplies: 6Last Post: 07-12-2016, 06:42 AM -
Mercury Tech: Minor Pitting
By icatchbigbass in forum Technical DiscussionReplies: 6Last Post: 11-16-2015, 11:48 PM -
Crank Journal Pitting
By marathon6 in forum Technical DiscussionReplies: 15Last Post: 12-18-2007, 01:17 PM -
Under Pump Drifeshaft pitting
By Tom Foley in forum Technical DiscussionReplies: 7Last Post: 12-16-2007, 06:35 PM
