Results 1 to 14 of 14
12-07-2022, 05:30 PM #1
Water temperature gauge advice needed
So I have a newly built 225X and water pressure is great. My hand under the water I'd guess what's coming out is 115-120 degrees.
I bought a new temperature gauge and sending unit. Problem is the hash marks are at 100, 150, 200, and 250 in about a 90 degree sweep. The needle barely moves above 100.
At 4500 rpm I have ~17 psi water pressure. I've searched for a gauge with a full sweep closer to 270 degrees but I'm not finding what I need.
Any suggestions? It's 2 1/8"\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
Grand Sport Elite with a Driefort Special 225x.
Checkmate Pulsare 2100 with a 2009 eTec 225 HO. *MOTOR FOR SALE* Getting a 250 Pro XS installed soon.
12-07-2022, 05:39 PM #2
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,136
- 512
- 736
- 1476
- 6222
- 3 Post(s)
Fill in the holes....Garmin and no more guessing
12-07-2022, 05:52 PM #3
This Autometer goes down to 60*F
https://www.autometer.com/2-5-8-low-...-pro-comp.htmlLet's go Brandon!
TraceF3 thanked for this post
12-07-2022, 05:57 PM #4\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
12-07-2022, 05:59 PM #5\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
12-07-2022, 07:25 PM #6
Get the old smartcraft gauge. It'll show you what the computer sees.
12-07-2022, 07:28 PM #7
Yes and No
12-07-2022, 08:10 PM #8
Brucato will not support smarcraft.
Faria makes a 2-1/8 gauge thats 60 to 220 deg. works great on outboards. I have three in my dash, one for each head and one for water temp. I have an extra one or two at home if you want a used one. I use them with 1/8 npt senders but they also come with a contact type one that mounts on a screw. Let me know if I can help.
12-07-2022, 08:13 PM #9
12-07-2022, 10:12 PM #10
Supporting Member
- Apr 2003
- 6,136
- 512
- 736
- 1476
- 6222
- 3 Post(s)
I was not aware that it would no longer support smartcraft with the aftermarket ecu. I ran Garmins on my 300X rigs.
12-07-2022, 11:48 PM #11
5000 RPM
- Sep 2019
- Lake Keowee, SC
- 225
- 20
- 46
[QUOTE=TraceF3;3370548]So I have a newly built 225X and water pressure is great. My hand under the water I'd guess what's coming out is 115-120 degrees.
I have not seen a 270* sweep temperature gauge. Is this Livorsi gauge a bit better Trace? Not ideal but perhaps slightly better.
12-08-2022, 06:35 AM #12\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
12-08-2022, 06:40 AM #13
Yessir. A 225X block with a laser intake. He drilled out the 2 water passages and tapped in flow restrictors, and set this powerhead right on my 280 mid. I'm at the low starting end of the 2.5L learning curve; I thought a 225X is a ProMax. I told Dave from the get-go that I'd have to trust him to give me what I felt I needed. And I think he has.
I live in a county where I run 20 miles in a 25 - 30 mph speed zone before I get to water (Lake George) where I can run fast. And then the lake may be rough if it's windy because it's a pretty big body of water. So consequently, my boats rack up most of the hours below 3500 rpm. A race built 280 isn't the ideal motor for my application so I went looking for a better alternative.
Dave was a pleasure to deal with. And the motor runs great.Last edited by TraceF3; 12-08-2022 at 06:44 AM.
12-08-2022, 03:06 PM #14
You are correct sir
water temperature gauge
By TOMATIS in forum Technical DiscussionReplies: 7Last Post: 11-16-2010, 11:56 PM -
some help with water temperature gauge for a 2.5 merc
By TOMATIS in forum Electronics, Audio Systems, and WiringReplies: 2Last Post: 11-13-2010, 11:43 AM -
Mercury Tech: Temperature Gauge and Trim Gauge
By mbrien in forum Technical DiscussionReplies: 0Last Post: 03-10-2010, 09:35 AM -
need advice on my water pressure gauge
By brockshydro in forum Technical DiscussionReplies: 7Last Post: 03-31-2009, 09:13 PM -
How to Check a OMC Water Temperature Gauge???
By MrCougar in forum Technical DiscussionReplies: 1Last Post: 02-19-2002, 11:57 AM
