Results 1 to 15 of 15
    Apr 2010
    Jacksonville, Florida
    Offshore Single Trim Ram Diagram
    Does anyone have a clear diagram of how the Mercury seal kit parts for Single Trim Ram is assembled you would be able to send me? I have the one below, but its not real clear. Thanks.
    2016 Allison Grand Sport
    225 Promax
    Jun 2009
    Bristol, Connecticut
    I'll post some pics but what's not clear about it?
    Jun 2009
    Not really a diagram hope it helps
  4. Likes Ace liked this post
    Jun 2009
    Ur gonna want to throw that short crush pin in the garbage and use a screw with jam nut
    Don't reuse the retainer spring because you'll destroy it taking it out if you need to service it again
    The kit I had didn't have the top scraper seal so I found a replacement
    Here are the part number for the new scraper seal and removable retaining ring
    SINGLE RAM TRIM
    Cap scraper seal W 31.7 X 38.1 X 3 WPB AR1815-E0 NOK
    Cap spring retaining ring Smalley WH-157
    All the other o-rings are easy to place as they really only fit one way, most of them are similar
    Use air on the lower hose fitting to pop the lower cup outta the cylinder
    If there is a specific question about the diagram I'm sure many can answer
  6. Thanks wcarlyle thanked for this post
    Likes David - WI liked this post
    Apr 2010
    Quote Originally Posted by Aaronhl View Post
    Thanks, this helps. I was having a hard time reading the writing, but probably not necessary.
    225 Promax
    Jun 2009
    Quote Originally Posted by wcarlyle View Post
    My bad I thought that was a picture you took with the paper on your desk in full size in person - I have a full PDF copy I will post
    Jun 2009
    That is not the one
    Jun 2009
  11. Likes David - WI liked this post
    Jun 2009
    Those are the PDF files you can download - Pages 1 AND 2 - Working on a picture file I can post
    Jun 2009
    Front page
    Back page
    Instructions came with this kit:
  14. #11
    Jun 2009
    few other tid bits,
    could probably use an oval head for the counter sink instead of hex head
    and a jam nut for the other side, I believe it's a 2" bolt?? easy access by hand
    Apr 2010
    Thank you so much Aaron, this is just what I needed. The picture I posted was from another post I saw on this site from 2006. I really appreciate this.
    225 Promax
  16. Thanks Aaronhl thanked for this post
    Jun 2009
    Glad I can help you are on the same journey I was on this time last year lol
    I wanted to document myself incase I pickup another couple older mid sections
  18. Thanks wcarlyle thanked for this post
  19. #14
    Apr 2010
    I am so thankful all of you nice people are here to help with these older motors. Thanks again..
    225 Promax
  20. #15
    Jun 2018
    Floating around
    Handy info here
  21. Likes wcarlyle liked this post
  1. New Trim Ram (single ram offshore style)
    By 2.5-21 in forum Misc. Parts and Accessories
    Last Post: 12-23-2016, 11:21 AM
  2. Trim Hose for an Offshore Single Ram Mid!!
    By Hydrogasm in forum Parts Wanted
    Last Post: 10-03-2016, 04:57 PM
  3. How to speed up single ram offshore trim
    By dondante in forum Technical Discussion
    Last Post: 05-10-2016, 12:52 AM
