Results 1 to 4 of 4
    Jan 2020
    Pinole, Ca
    300x/optimax bleed fitting thread????
    What is the thread on the reed plate or front half of 3.0L fuel injected engines? 300x 250xs etc.
    I measure it as a metric 0.75 thread pitch and 7.5mm dia. but that doesn't make sense to me. I am trying to locate some pipe plugs for these check valve holes....
    Thank you
    La rosca es una decimosexta rosca nacional de grifo de pipa hembra.
    Jan 2020
    Pinole, Ca
    Gracias maestro llave
    De nada
  1. 2.4 200 bleed fitting leaking
    By Merc 2.5 in forum Technical Discussion
    Last Post: 03-01-2018, 10:48 AM
  2. 300xs HD trim hose fitting thread damaged
    By Primal 98 in forum Technical Discussion
    Last Post: 12-27-2017, 03:36 AM
  3. air horn bleed fitting broken off on merc 280
    By davidmercury in forum Technical Discussion
    Last Post: 09-04-2012, 06:41 AM
  4. Threaded type bleed fitting
    By mach351 in forum Technical Discussion
    Last Post: 03-05-2010, 11:18 PM
  5. Bleed fitting part number?
    By Burke Kilgour in forum Technical Discussion
    Last Post: 06-15-2003, 11:12 PM
