Results 16 to 25 of 25
Thread: 260hp to 245hp conversion
12-01-2022, 06:57 PM #16Junior Member
- Mar 2016
- n/a
- 11
- 9
I didn't get your comment until I took the photos🤣😂 Thank you!
12-01-2022, 07:00 PM #17Junior Member
- Mar 2016
- n/a
- 11
- 9
I do have another set as well but can't get to them until tomorrow. Will post them when I get the chance.
12-01-2022, 07:17 PM #18
Don’t forget about the bleed lines needed . Here’s my 245
12-01-2022, 07:29 PM #19
12-01-2022, 08:51 PM #20Junior Member
- Mar 2016
- n/a
- 11
- 9
12-01-2022, 09:00 PM #21
12-01-2022, 09:13 PM #22
If he has a 260 block it won’t have bleed fittings on the cylinders. They can be installed but that’s usually more trouble than it’s worth. A better option for a carbs (or any wet-reed system like laser efi) is to connect all the bleed lines together into one line and run that back to the fuel tank. 1/8” line is sufficient. I’d recommend your “#1” set of carbs. Again, this is pretty easy to do…..your only real issue where you will have to design something is the throttle linkage. And efi linkage won’t work, and a carb linkage won’t fit an efi front half. If I remember right (it was a while ago) I spaced a carb throttle bracket out about 3/8” and then made a custom rod to the carbs out of 1/8 round stock.
'95 STV "The Blue Goose"
12-01-2022, 09:16 PM #23
Put #72 jets in the mains of those whm-21’s to start and you’ll be good. You’ll probably end up going down to a 70 or 68 eventually.
WOT77 thanked for this post
12-01-2022, 09:18 PM #24
And you’re going to need a 2.5 7peddle carb intake if you don’t have one already.
12-01-2022, 10:56 PM #25Junior Member
- Mar 2016
- n/a
- 11
- 9
Thank you for all of your input Mach351! That is very helpful! I'll definitely be using your input 👍!
WTB Mercury 260hp 245hp 2.5L small bearing crank
By crescentbar in forum Parts WantedReplies: 0Last Post: 01-19-2020, 01:03 PM -
245hp carbs
By alwayssomethin in forum Technical DiscussionReplies: 7Last Post: 03-29-2009, 03:44 PM -
2.5 200 efi how to get to 245hp
By jimmyz32 in forum Technical DiscussionReplies: 5Last Post: 03-03-2008, 06:59 AM
