Results 46 to 49 of 49
12-02-2022, 06:33 PM #46Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
BL
Is this fuel only or fuel and spark?
12-03-2022, 12:56 AM #47
[QUOTE=oldschoolltv;3369937]Or do you still have this one
[/QUO]
Aah memories! Sold that in 2012, it was quite the antique and wasn’t liking the frequent use too much. The cracks were starting to add up. Some guy drove all the way from AZ to FL and bought it. Even after the axle on the trailer broke after the test drive and one wheel cambered into the side of the hull and burned a slot right through the side. He still wanted it, didn’t care.
-BL
oldschoolltv liked this post
12-03-2022, 01:00 AM #48
This ECU is fuel and spark. It has an external 400w CDI power supply that puts 400v primary to the ignition coils. The ECU has complete control over the power supply and varies the power depending on engine state, cranking, low speed high speed etc.
-BL
powerabout thanked for this post
12-03-2022, 01:02 AM #49Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
LakeFever liked this post
Yamaha HPDI build/port work (let's talk port timing)
By canuckr in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 48Last Post: 10-04-2023, 07:35 AM -
Retrofitting Evinrude Factory Trim Questions
By Flex in forum Props, Setup, and RiggingReplies: 9Last Post: 01-28-2019, 10:17 AM -
Mercury 115hp inline six port map/ power port dimensions
By janihei in forum Technical DiscussionReplies: 33Last Post: 03-06-2017, 11:31 AM -
Info on designing/retrofitting pads on V's???
By Steve2ManyBoats in forum Technical DiscussionReplies: 7Last Post: 12-28-2006, 07:04 PM -
Retrofitting small shaft lightining et to large shaft?
By Pete Budka in forum Technical DiscussionReplies: 2Last Post: 07-22-2005, 05:19 PM
