Results 31 to 45 of 49
12-01-2022, 01:09 PM #31
LakeFever liked this post
12-01-2022, 01:24 PM #32
Just living the dream my old friend. Still running the Lavey, we spend a lot of time on a house boat we bought about 20 years ago. Fishing in an old 1992 Nitro with a 90 Johnrude and making enemies on a Polaris Virage Ski.
I messaged Sleekster on Faceplace, he is still kicking as well.L.T.
Laker liked this post
12-01-2022, 07:50 PM #33Member
- Sep 2021
- New Richmond, Ohio
- 91
- 27
what is the cost for a set up like yours
12-02-2022, 09:14 AM #34
As far as the cost, you'd have to contact them directly. This thread isn't trying to sell anything its mainly to show the mods to these motors necessary to bring them into the 21st century or in the case of the Ficht/eTec, to convert them to a more flexible, performance oriented port EFI than the stock DFI. There are a half dozen ECUs out there you could use for these conversions although none have touchscreen control, injector open/close rate control or can integrate the factory charging system. Maybe even more, like flexible map sizes. Some are just so darn complicated and not really born for outboard use like this one.
Anyway... speaking of Ficht eTec, here's some pics of a 250hp Ficht HO being converted to a 12 injector setup (6 main 6 enrichment for NOS) using an eTec front half. The 6 enrichment injectors are used by the ECU when the NOS is turned on for a seamless transition and to allow normal sized injectors to be used on the mains in order to preserve low speed control. I expect this one to be on the water early next year, if I can procure a boat to be able to handle well over 300hp
-BLLast edited by BLisBack!; 12-02-2022 at 09:18 AM.
12-02-2022, 09:18 AM #35Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Very nice setup, well done BL
12-02-2022, 09:20 AM #36
12-02-2022, 09:28 AM #37
rgsauger liked this post
12-02-2022, 09:30 AM #38
12-02-2022, 09:43 AM #39
powerabout thanked for this post
12-02-2022, 09:56 AM #405000 RPM
- Dec 2019
- Spring Lake MI
- 494
- 38
- 150
- 448
This is awesome! Great work!
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
12-02-2022, 10:00 AM #41
12-02-2022, 10:03 AM #425000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
this thread is cool
12-02-2022, 10:18 AM #43
Don't need these DFI mounts/holes anymore, plug 'em. I'm actually a big fan of DFI but there's simply no way to run NOS with them and use them as enrichment as well. So you would end up with hoses going everywhere using the archaic on/off style solenoids in those kits for gas.
Adjustable regulator...
-BL
12-02-2022, 05:25 PM #44
You need a test boat for that one?
12-02-2022, 05:43 PM #45
Yamaha HPDI build/port work (let's talk port timing)
By canuckr in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 48Last Post: 10-04-2023, 07:35 AM -
Retrofitting Evinrude Factory Trim Questions
By Flex in forum Props, Setup, and RiggingReplies: 9Last Post: 01-28-2019, 10:17 AM -
Mercury 115hp inline six port map/ power port dimensions
By janihei in forum Technical DiscussionReplies: 33Last Post: 03-06-2017, 11:31 AM -
Info on designing/retrofitting pads on V's???
By Steve2ManyBoats in forum Technical DiscussionReplies: 7Last Post: 12-28-2006, 07:04 PM -
Retrofitting small shaft lightining et to large shaft?
By Pete Budka in forum Technical DiscussionReplies: 2Last Post: 07-22-2005, 05:19 PM
