Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
    Jun 2018
    Floating around
    Quote Originally Posted by Laker View Post
    Look it up on Google.
    VSFI
    i cant seem to find this? Got a link by chance?
  2. #17
    Lannon WI
    2006 Action Marine Comp
    1980 Ventrua 2
  3. Thanks LakeFever thanked for this post
    Likes LakeFever liked this post
  4. #18
    Aug 2012
    Ignition
    Quote Originally Posted by CUDA View Post
    I'm Impressed, how in the world did you figure out the even fire timing plate, so few of those cranks were made?
    I had a even fire crank back in 1985, but don't remember anything but the $2500.00 price, I just Googled what $2,500. was
    worth in todays money, $7,000.
    Great Job
    I bought that motor 15 years ago and when I disassembled it I noticed it was and even fire trigger. I forget what I did with that trigger base but I agree they are very rare. I was surprised it was even fire bc the guy wasn’t into racing at all. Then the block just sat in the corner of the shop for 15yrs.
    I ran an even fire crank in a couple diff crossflows so I may have used it in one of them. I went back to odd fire bc I didn’t notice any diff except a smoother idle and diff exhaust sound. I actually think the odd fire has a better sound. Kinda the way Harley’s sound better than even fire Japanese twins (but make less power! Lol)
    Anyway, this ECU has a separate 400w CDI power supply and uses it’s own digital sensors so it’s not using any of the OEM stuff. It does use the OEM coils but runs almost twice the voltage through them, around 400v primary.
    -BL
  5. Likes Laker liked this post
  6. #19
    PARADISE /Naples
    Really COOL projects
  7. #20
    MIAMI FLORIDA
    Pretty cool xflow, still got the carbs you could run dual fuel lol.. Why 2 crank position sensors...
  8. #21
    Houston, TX
    Outstanding project! Thanks for sharing!
  9. #22
    Aug 2012
    Crank sensors
    Quote Originally Posted by H2OPERF View Post
    Actually it uses 3. One is for sync, all ECUs use a sync sensor to determine position so the firing order starts off right. The second is the cyl trigger sensor, triggered on every cyl when in position to fire. The 3rd is unique to this ECU (VSFI) in that it is for quick starts. Most ECUs have to spin a crank Rev or two before they can determine RPM in order to correctly fire a cyl. VSFI uses the 3rd sensor as a magneto style ignition similar to the way a lawn mower ignition works. Just fires with no RPM data necessary. You set it right at the spot , say 5deg BTDC, where you want to fire the cyls until the ECU knows the rpm. This enables the engine to start immediately in under one crank Rev. Makes for incredibly fast starts, much faster than OEM systems. You can see it working in that Start YouTube vid. Then when RPM is determined by the ECU, the 3rd sensor is disabled and it continues using the main cyl trigger sensor. Very cool.
    -BL
  10. Likes moatorbotin, Laker, rgsauger, powerabout liked this post
  11. #23
    PARADISE /Naples
    What is your background ?
    Your pretty darn sharp!
    https://youtu.be/CCCx1j8WsHU
  12. #24
    Aug 2012
    Thanks! I do make it a point to read both sides of the cereal box in the mornings.
  13. #25
    MIAMI FLORIDA
    Interesing, 4 strokes use the sync bc they run on a 720 degree cycle with a 2 stroke your running on a 360... with missng teeth on the reluctor the ecu can tell crank position with 1 sensor,
  14. #26
    Jun 2018
    Floating around
    Did you use egt’s only for tuning?
  15. #27
    Cincinnati
    Bruce!
    L.T.
  16. Likes powerabout liked this post
  17. #28
    Aug 2012
    OEM systems can use one sensor because they usually have custom made flywheels where the hall sensor is designed to sense a change in the raised trigger surfaces on the flywheel. This can be seen on the Ficht/ETec flywheel just under the starter ring. But a universal ECU like this one is intended to go on any motor, custom flywheel is not gonna happen, so a separate sync sensor is used. Also flying magnets (about .15” diam) are used so you can setup the sensors in any configuration. No custom flywheel is needed.
    This ECU also has a tethered rich/lean handheld control, sometimes called a “steam wheel” where the user can adjust the mixture at speed while watching the EGTs. So you can tune as close to melting point as you wanna get so yes EGTs are a must. I hear the next version will have individual cylinder digital EGTs which will be real cool!
    -BL
  18. Thanks LakeFever thanked for this post
    Likes Laker, LakeFever liked this post
  19. #29
    Aug 2012
    Quote Originally Posted by LaveyT View Post
    Bruce!
    Dude! It’s been a long time! How’s it going!?!
    -BL
  20. #30
    Jun 2018
    Floating around
    Ive been dreaming about something like this for a while. I contemplated trying mega squirt but this seems much less involved. Im going to give the merc brain a go with laser and adjustable fpr but if i have too many challenges, this system looks mighty attractive. Thanks for sharing your build a details
  21. Likes Laker liked this post
  1. Yamaha HPDI build/port work (let's talk port timing)
    By canuckr in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-04-2023, 07:35 AM
  2. Retrofitting Evinrude Factory Trim Questions
    By Flex in forum Props, Setup, and Rigging
    Last Post: 01-28-2019, 10:17 AM
  3. Mercury 115hp inline six port map/ power port dimensions
    By janihei in forum Technical Discussion
    Last Post: 03-06-2017, 11:31 AM
  4. Info on designing/retrofitting pads on V's???
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 12-28-2006, 07:04 PM
  5. Retrofitting small shaft lightining et to large shaft?
    By Pete Budka in forum Technical Discussion
    Last Post: 07-22-2005, 05:19 PM
