Results 1 to 7 of 7
Thread: gaffing gps speedco antenna
11-28-2022, 06:03 PM #1
5000 RPM
- Nov 2001
- upstate newyork
- 437
Gauge tests fine. Apparently need a new antenna. Is gaff rig the only source.Thanks
11-28-2022, 06:31 PM #2
5000 RPM
- May 2001
- Maine
- 878
- 27
- 21
- 104
I had a brand new Livorsi GPS speedo and antenna installed in my new STV back in 2010 and it gave me issues. It would always pass the calibration process when the ignition was turned on. I would be driving along and sometimes the needle would bounce or even go to 0 at will. I sent it back to Livorsi and they tested it and said there was nothing wrong with it. So I cut off about 3" of the antenna cable at the head end, re stripped it and re crimped new solder-less connections and it fixed it... never had another issue.
11-28-2022, 07:31 PM #3
5000 RPM
- Nov 2001
- upstate newyork
- 437
The speedo goes through initiation process when the ignition is turned on but fails to acquire a signal. I bought the unit used. Think it might have the wrong antenna. Gaffrig tested the unit and said it was ok. The antenna doesn't say gaff rig on it which leads me to believe its the wrong one for my application. Thanks for the reply
11-29-2022, 06:27 AM #4
5000 RPM
- May 2001
- Maine
- 878
- 27
- 21
- 104
Is it one of the older style antennas with the internal battery? Could you post a photo? These antennas were round with a top you could unscrew. The battery was round & soldered to a circuit board, some have had success replacing the battery. There was a in-depth write up on the antennas with the internal battery on another forum I found when trying to figure out the problem I was having. I think I just googled Livorsi GPS antenna. I will see if I can find it again.
11-29-2022, 07:27 AM #5
5000 RPM
- Nov 2001
- upstate newyork
- 437
It's the new style...no internal battery. Gaffrig says I have to retain the three prong connector and solider it to the new antenna lead. I'm wondering if there's a way too test the antenna.
11-29-2022, 02:05 PM #6
5000 RPM
- Nov 2001
- upstate newyork
- 437
I finally figured it out: I have the wrong antenna. I need one with a different chip designed to work with the gaffrig gauge.Thanks for the reply.
11-29-2022, 02:20 PM #7
5000 RPM
- Nov 2001
- upstate newyork
- 437
Does anyone know if I can you a different mfg. antenna than the gaffrig. They want over 200 bucks for a new one.
GPS Antenna ONLY $104.95
By moomba in forum Electronics, Audio Systems, and WiringReplies: 107Last Post: 01-21-2021, 03:05 PM -
GPS antenna
By Tooned In in forum Electronics, Audio Systems, and WiringReplies: 1Last Post: 02-07-2018, 09:00 AM -
What to do about VHF antenna
By kwgst in forum General Boating DiscussionReplies: 3Last Post: 12-03-2013, 10:07 AM -
gps antenna
By BRB in forum Parts WantedReplies: 0Last Post: 11-26-2013, 11:43 PM
