Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
    Aug 2017
    Grand Cayman
    Offset Low Water Pickup Holes in Nosecone
    Anyone seen this sort of thing before? Is this designed to create a “drag bias” on one side of the nosecone to help offset the torque of the propeller? This unit has a torque tab as well, although it’s not bent as much as the typical torque tab, so I’m wondering if this water pickup offset helps offset the torque??
    Attached Thumbnails Attached Thumbnails A73174E1-71D7-4578-983E-A58704D4235B.jpg
    Pekin, IL
    I believe that to be an Allison modification. Show a pic of the skeg cuz the Ally mod involves the skeg also.
    Rock
    Team Junk
  3. Thanks CI STV thanked for this post
    Likes Michael J Giesler liked this post
    Not buying any drag "bias change" for torque reduction. I saw no change in my testing. Titus used to do several different intake configurations and I'm sure others did as well. I have the starboard hole in my Sporty plugged, it increased speed .7 MPH. But I would only do it in a motor that makes tons of water pressure.
    Click for Countdown to the Romp
  5. Thanks CI STV thanked for this post
    Likes rgsauger, Baker343 liked this post
    Aug 2017
    Grand Cayman
    Quote Originally Posted by rock View Post
    Rock
    I’ll take a picture of the skeg/tab and post it up later.
    Aug 2017
    Grand Cayman
    Thanks. I was just wondering why it was off-centered like that, and that’s all I could come up with, lol.
    Pekin, IL
    I purchased a sportmaster from a friend because he said the motor would get hot. He had been using it on his Ally when it was stock and it worked fine. Motor is a 15" 200xs ros. After modifications the hot issue appeared. I bought it cuz I needed a 15" lower and figured I could make it work. Turned out he had a 1/2" water tube. I changed over to the 3/4" I have always ran and it has never failed me. Had lower on several STVs and a couple Allisons. As far as the mods go I could not tell you if it made any difference or not. My guess is their blocked hole was to make the supply to the prop cleaner. I think the 3/4" tube is necessary with only 2 holes.
    Rock
    Team Junk
  9. Thanks CI STV thanked for this post
    Likes David - WI, rgsauger, Baker343 liked this post
    Aug 2017
    Grand Cayman
    Rock
    Thanks. I’m running a 3/4” tube and it was making right around 20 psi with my other XR6 with Bobs nosecone.
    Here’s what the tab looks like:
    Minnesota
    I was told it gives cleaner water to the starboard side for the prop.
    Quartermaster
    XB2002 W/S3000
  12. Thanks CI STV thanked for this post
    Likes David - WI, 25two.stroke liked this post
  13. #9
    Quote Originally Posted by CI STV View Post
    That's a common mod. And THAT one is supposed to help with torque steer. It creates a low pressure area to "pull" the gearcase straighter. I have not tested it because there's no claimed speed increase and my setup doesn't present much torque steer.
    Minnesota
    Sorry if there was any confusion. I was replying to the offset intake hole mod not the torque tab mod.
    Quartermaster
    XB2002 W/S3000
  15. Likes Michael J Giesler liked this post
  16. #11
    Quote Originally Posted by Scott in MN View Post
    I think that theory is total crap. Next time somebody tells you that ask for proof. Nobody has ever been able to show any evidence of it. "Clean water" and "rising water" off the transom are wildly overrated.
    Aug 2017
    Grand Cayman
    Yep, I know what the torque tab is for and how it works, lol. I haven’t come across any high speed outboard with a surfacing prop that doesn’t need one though.
  18. Likes Baker343 liked this post
  19. #13
    Aug 2017
    Grand Cayman
    That’s going to be really hard to prove…
  20. #14
    Minnesota
    That is true. How do you explain the .7 mph increase with the starboard hole plugged?
    Meant the speed inrease to transomstand.
    Quartermaster
    XB2002 W/S3000
  21. Thanks CI STV thanked for this post
  22. #15
    Pekin, IL
    He forgot the bunny that day.
    Rock
    Team Junk
  23. Likes CI STV liked this post
  1. bob's nosecone/low water pickup installation
    By reacler in forum Props, Setup, and Rigging
    Last Post: 05-08-2020, 09:35 PM
  2. Mud or sand in low water pickup nosecone
    By The Bilge Idiot in forum Technical Discussion
    Last Post: 09-04-2006, 01:54 PM
  3. Aftermarket low water pickup nosecone help
    By Mr Walker in forum Technical Discussion
    Last Post: 06-30-2006, 09:03 AM
  4. Aftermarket low water pickup nosecone help
    By australian ski racer in forum Technical Discussion
    Last Post: 06-20-2006, 06:55 AM
