Results 1 to 11 of 11
11-24-2022, 09:25 AM #1Team Member
- Apr 2014
- nj
- 498
- 16
- 116
Easiest way to use ddt on engine off boat
Picked up a Rinda DDT and it works well however I have 5 or 6 engines on stands that I would like to verify hours before I sell them . Question, what is the best / easiest/ safest method to power up an engine in order for the DDT to operate ?
Thanks
Larry
11-24-2022, 10:33 AM #2
I have done compression test on a pallet, by hooking battery cables up, and plugging in mercury control box with integrated ignition switch. Probably easier ways, like powering up the purple wire in engine harness.
11-24-2022, 01:02 PM #3Team Member
- Apr 2014
- nj
- 498
- 16
- 116
exactly what im avoiding to do
11-24-2022, 01:14 PM #4
About 2 minutes to remove cowl, hook jumper cables, and engine harness to remote control harness. All while your laptop is booting up.
11-25-2022, 05:39 PM #5Team Member
- Apr 2014
- nj
- 498
- 16
- 116
no booting up , have hand held ddt
Thanks
11-25-2022, 07:05 PM #6
I'm guessing your just looking for ignition power? If you want something that fits in your pocket, here you go.
12.6v 3 cell 2200mah lipo battery.
2 deans connectors.
1 bullet connector for purple wire in cannon connector.
1 alligator clip for ground.
A little elbow grease, 3' wire, solder, and iron.
11-26-2022, 09:13 AM #7Team Member
- Apr 2014
- nj
- 498
- 16
- 116
Thank you very much , your very smart guy indeed . I was thinking more on something like this , I have **** load extra harnesses so I cut one to say 10 ft , plug into engine , grab the purple and the ground hook up 12 v lawn tractor battery and done ? Will that work ? Only concern I have is say the positive had loose connection could maybe spike the ecu ?
Thanks
11-26-2022, 10:20 AM #8
I think smart is a overstatement maybe persistent.
That would work great if you have a doner harness. A jump box would also work.
You get a little arcing on the big jobs. Just try to keep it isolated to ground on engine block.
11-26-2022, 12:50 PM #9Team Member
- Apr 2014
- nj
- 498
- 16
- 116
so dont use a ground in the harness ? Just use the purple out of harness and run that to positive and separate ground from battery to block ?
11-26-2022, 01:07 PM #10
You could use ground in harness, or not. I just wouldn't recommend arcing your harness plug or battery. Probably not a big deal, unless your battery explodes in your face. You could put a switch, or sacrificial plug in one of the wires, or use a alligator clip to block for ground.
11-26-2022, 09:54 PM #11Team Member
- Apr 2014
- nj
- 498
- 16
- 116
thank you
Article: Updating your dash is one of the easiest and most affordable ways to breathe new life into your boat.
By Scream And Fly in forum vBCms CommentsReplies: 0Last Post: 04-27-2011, 07:02 PM -
easiest way to get boat off trailer?
By hst714 in forum Technical DiscussionReplies: 6Last Post: 09-14-2010, 04:04 PM -
Mercury Tech: What's the easiest way to id 2.4 or 2.5 Merc
By mt1973 in forum Technical DiscussionReplies: 1Last Post: 06-08-2010, 03:37 AM -
Easiest way to remove a VRO
By 81hydrostream in forum Technical DiscussionReplies: 4Last Post: 04-21-2009, 09:29 PM -
Easiest boat to drive?
By flabum1017 in forum The Scream And Fly LoungeReplies: 11Last Post: 04-29-2008, 10:51 AM
