Results 1 to 11 of 11
    Apr 2014
    nj
    Easiest way to use ddt on engine off boat
    Picked up a Rinda DDT and it works well however I have 5 or 6 engines on stands that I would like to verify hours before I sell them . Question, what is the best / easiest/ safest method to power up an engine in order for the DDT to operate ?
    Thanks
    Larry
    Nov 2021
    N. Idaho
    I have done compression test on a pallet, by hooking battery cables up, and plugging in mercury control box with integrated ignition switch. Probably easier ways, like powering up the purple wire in engine harness.
    Apr 2014
    nj
    exactly what im avoiding to do
    Nov 2021
    N. Idaho
    About 2 minutes to remove cowl, hook jumper cables, and engine harness to remote control harness. All while your laptop is booting up.
    Apr 2014
    nj
    no booting up , have hand held ddt
    Thanks
    Nov 2021
    N. Idaho
    I'm guessing your just looking for ignition power? If you want something that fits in your pocket, here you go.
    12.6v 3 cell 2200mah lipo battery.
    2 deans connectors.
    1 bullet connector for purple wire in cannon connector.
    1 alligator clip for ground.
    A little elbow grease, 3' wire, solder, and iron.
    Apr 2014
    nj
    Thank you very much , your very smart guy indeed . I was thinking more on something like this , I have **** load extra harnesses so I cut one to say 10 ft , plug into engine , grab the purple and the ground hook up 12 v lawn tractor battery and done ? Will that work ? Only concern I have is say the positive had loose connection could maybe spike the ecu ?
    Thanks
    Nov 2021
    N. Idaho
    I think smart is a overstatement maybe persistent.
    That would work great if you have a doner harness. A jump box would also work.
    You get a little arcing on the big jobs. Just try to keep it isolated to ground on engine block.
    Apr 2014
    nj
    so dont use a ground in the harness ? Just use the purple out of harness and run that to positive and separate ground from battery to block ?
    Nov 2021
    N. Idaho
    You could use ground in harness, or not. I just wouldn't recommend arcing your harness plug or battery. Probably not a big deal, unless your battery explodes in your face. You could put a switch, or sacrificial plug in one of the wires, or use a alligator clip to block for ground.
    Apr 2014
    nj
    thank you
  1. Replies: 0
    Last Post: 04-27-2011, 07:02 PM
  2. easiest way to get boat off trailer?
    By hst714 in forum Technical Discussion
    Last Post: 09-14-2010, 04:04 PM
  3. Mercury Tech: What's the easiest way to id 2.4 or 2.5 Merc
    By mt1973 in forum Technical Discussion
    Last Post: 06-08-2010, 03:37 AM
  4. Easiest way to remove a VRO
    By 81hydrostream in forum Technical Discussion
    Last Post: 04-21-2009, 09:29 PM
  5. Easiest boat to drive?
    By flabum1017 in forum The Scream And Fly Lounge
    Last Post: 04-29-2008, 10:51 AM
