Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Sep 2004
    MICHIGAN
    If I were to start it now after it lost so much compression in only one cyl from solvents and lubes, (58 psi down to 25 ) I'm assuming instead of a miraculous fix, I could do damage to the cyl / piston? Wouldn't pulling the head and only being able to just see the cyl wall and piston top still give limited info about the cause?
  2. #17
    May 2013
    Huntiington Beach Ca
    Pull both heads for peace of mind. It aint that big of a deal and if the cylinders are good you have more access for lube or some magic elixir.
  3. #18
    Sep 2004
    MICHIGAN
    I'll take your advice, I think it would be the best route especially since I'm not in a pinch for it, it's a spare, but I still want the peace of mind knowing it is ready to go. Oddly as I accumulated the four engines I wound up with only one exhaust tuner. I have another hydro I'm putting together with a 12" mid section. What should I be looking for as far as tuners go?
  4. #19
    Apr 2007
    Big Pine Key, Fl
    What 2.5 engines are you working on?? steel bore,200,225 or nic 245,260,300.I see you are having good luck freeing up your engines ,,just wondering what you are dealing with..Since your compression is 165 you already have modified powerheads?? When you ask about tuners I think mercury knew what they were doing and would go in that direction...
  5. #20
    Feb 2006
    Be real careful using methanol as a solvent as it has low(like none) lubricity qualities. Once the castor is gone you're basically metal to metal and could cause a snag or metal transfer. I'd be more inclined to use WD-40, kerosene, diesel fuel, premix gas, etc. JMHO Good luck!
  6. #21
    shreveport,la
    Takes very little time to pull a head and intake to pull the questionable piston out and get a look at it. If these were my engines and it took that much to get them rotated over I’d tear them down for a proper cleaning and reassembly
    Erik Kiser
  7. Likes laser_ED, OnPad, LakeFever, stoker2001 liked this post
  8. #22
    Sep 2004
    MICHIGAN
    I took the head off, cast iron cylinders and a perfect non-scored bore. It has the "o" ring type head gasket. Two of the six cylinders had 165 psi compression, then it went downhill from there to the worst being 25 psi.
  9. #23
    Nov 2021
    N. Idaho
    Not that much more work to take the intake off, and slide the piston and rods out, like said in above post.
  10. Likes rgsauger liked this post
  1. Mercury Tech: Mirage/ Merc stored since 2013
    By Groucho in forum Technical Discussion
    Last Post: 04-25-2019, 04:21 PM
  2. Mercury Tech: Starting a motor that has been stored for 9 years
    By 93Intimidator193 in forum Technical Discussion
    Last Post: 08-14-2018, 11:55 AM
  3. Running Motor after fogged and stored
    By Reddawgzulu in forum Technical Discussion
    Last Post: 11-16-2006, 12:53 PM
  4. stored messages
    By muddley in forum The Scream And Fly Lounge
    Last Post: 11-17-2005, 06:28 AM
  5. digital efi stored data-2.5 merc
    By randy 77zt in forum Technical Discussion
    Last Post: 03-02-2002, 12:21 PM
