Results 1 to 15 of 17
Thread: what size head gaskets
11-18-2022, 11:26 PM #15000 RPM
- Nov 2013
- palatka fl
- 117
guys 1993 v6 2.5 200 carbs after rebuild i discovered my heads maybe shaved too much so could i go to a thicker head gasket and what size now useing stock size comp nos are 135 to 142 range all cylinders thanks for advice
11-19-2022, 12:05 AM #2
Perfect.
David - WI, rgsauger liked this post
11-19-2022, 05:29 AM #3
Or you could install new heads!
11-19-2022, 10:59 AM #4
27-8228441
Thats the 1.2 mm head gasket.
But...you may already have that on your engine. Your compression numbers are not too high for 91 octane. If you are worried about it then turn the timing down to 23 btdc on cylinder #1. You will be good.
11-19-2022, 11:38 AM #5
promax 225 heads with 1 mm gasket
11-19-2022, 11:54 AM #6
They made a 1.5mm gasket also. Pretty hard to find nowadays. It would lower you a bit, but probably not worth the search effort.
'95 STV "The Blue Goose"
11-19-2022, 12:15 PM #7
With those compression numbers should be fine running 91-93 premium fuel.
25two.stroke liked this post
11-19-2022, 01:02 PM #8
Yes. 1.5 mm head gasket is 27-840322 and they are backordered from mercury rn.
11-19-2022, 11:51 PM #95000 RPM
- Nov 2013
- palatka fl
- 117
11-20-2022, 01:12 AM #10
I would think a healthy starter and battery, would spin that engine over no problem. I know my 2.5 at 130lbs, in sub freezing weather, has no problems, even with a group 24 battery.
I have stock heads if you want to trade.
11-20-2022, 01:07 PM #11
Sounds like you have a starter, battery, or voltage drop issue. nothing to do with compression.
11-20-2022, 01:18 PM #12
Yeah I start 180psi on 12v with a group 24 deep cycle
11-20-2022, 04:38 PM #13
Funny thing even the promax powerheads are now pictured with the diverters
Part 38 = 2 pieces of 1,5 inches and 2 pieces of 1,25 inches
OnPad liked this post
11-20-2022, 05:45 PM #145000 RPM
- Nov 2013
- palatka fl
- 117
thanks again guys batterys are new all 12 volt stuff new im useing 2 batterys for stating but at times the starter drags a little then kicks in will try another starter maybe buy new one cheers
11-20-2022, 06:07 PM #15
Could also be your solenoid.
2.5 gaskets head ,exhaust. Intake ,2.4 head
By eli in forum Misc. Parts and AccessoriesReplies: 5Last Post: 09-26-2020, 12:15 PM -
Early Merc 2.0 Head Gaskets and Water Jacket Gaskets
By silverbullet02 in forum Misc. Parts and AccessoriesReplies: 4Last Post: 10-25-2018, 07:11 AM -
Mercury Tech: Head Gaskets for 2.0
By frankydee in forum Technical DiscussionReplies: 7Last Post: 02-24-2009, 08:09 AM -
84 omc 235 head gaskets
By switzer in forum Technical DiscussionReplies: 3Last Post: 07-29-2003, 08:18 AM -
2.4 head gaskets any different from 2.5?
By O/B Dude in forum Technical DiscussionReplies: 2Last Post: 10-03-2002, 10:38 PM
