Results 1 to 12 of 12
Thread: LH carriers
    Jan 2020
    Pinole, Ca
    LH carriers
    One NOS carrier for a early CLE or big bearing LH case. Anything that is using a fishin propshaft. Brand new.
    On high performance LH carrier for a 2.5 sportmaster or late model CLE...anything with a big dia. propshaft and rear oil drain. Used in perfect shape.
    On high performance LH carrier for a 3.0 sportmaster or torquemaster. Used in perfect shape.
    $175 each + shipping or free local pickup...
ID:	512487Click image for larger version.
ID:	512488Click image for larger version.
ID:	512489Click image for larger version.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Jan 2020
    Pinole, Ca
    Got a LH small 2.5 sportmaster propshaft too. Part number 44-815495T
    Perfect used shape. $400
    May 2011
    England
    Still for sale?
    Jan 2020
    Pinole, Ca
    Looks like I do have both shafts you need used. LH and RH small spline big inner dia. propshafts. I will have to get the LH one from my friend. When I get them both in my hands ill post/send you pics of them.
  5. Thanks putt-putt thanked for this post
    Likes putt-putt liked this post
    Jun 2009
    Bristol, Connecticut
    By any chance do these use larger keys than the non race versions (fishing)
    Jan 2020
    Pinole, Ca
    They all use the same keys. Fishin, 2.5 sportmaster, cle etc.
    The 3.0L ones don't have keys as almost no 3.0L gearcase uses a key/slot.
    I can cut them and put oversized keys in them that still fit into the merc gearcase but are far less likely to spin. I do that on all the gearcases I build that have spun carriers in the past. If I tear one down thats spun it automatically gets cut and a longer/fatter key put in.
  8. Thanks Aaronhl thanked for this post
    Likes Aaronhl liked this post
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by putt-putt View Post
    Still for sale?
    Here are some pics of the shafts I have. The RH one is in about the same condition as the left. Both have visual wear lines, but they are smooth and hold pressure just fine. Bearing surfaces are perfect. The RH shaft has some pitting/roughness outside the seal area between the seal and the thrust taper; I guess that was from use in salt water at some time, but it doesn't affect the sealing. Both shafts hold pressure perfect. Let me know if you need them.
    RH:
ID:	513780Click image for larger version.
ID:	513781Click image for larger version.
    LH:
ID:	513783Click image for larger version.
ID:	513784Click image for larger version.
ID:	513785Click image for larger version.
  10. Thanks putt-putt thanked for this post
    May 2011
    England
    The RH looks about the same as the one I already have. Is there somebody known to the forum that repairs them?
    How are the faces of the thrust washer on the LH shaft, they look a little blue/black.
    Jan 2020
    Pinole, Ca
    Could these be re-chromed?
    They can be, but there is not really any need. They seal fine, and the chrome isn't peeling on the bearing surfaces...so why chrome them. There is a guy here somewhere that repairs driveshafts, so I bet he would do the propshaft if you needed it.
    Jan 2020
    Pinole, Ca
    The thrust faces are black from some nasty oil that was in the case. Turned gears and everything black...they are not blued from overheating.
    I found another RH shaft that is in very good shape.
ID:	514021Click image for larger version.
ID:	514022Click image for larger version.
  14. #11
    longisland ny lindenhurst
    Do you still have any counter carriers available? I'm looking for a stock carrier for fishing shaft.
    I'm also looking for a standard prop shaft and 20in drive shaft
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by 16ft superboat View Post
    I ended up building a LH case a month ago and used the NOS carrier in that.
    When you say you want a standard propshaft do you mean a RH fishin shaft? If so I'm sure I have that. I do not have a LH fishin propshaft. Driveshaft no...I've been going through a lot of those lately.
  1. hipo carriers
    By TEXAS20225 in forum Misc. Parts and Accessories
    Last Post: 05-18-2017, 10:38 AM
  2. H.D. bearing carriers
    By nelsoncat in forum Technical Discussion
    Last Post: 10-17-2002, 11:02 AM
  3. bearing carriers
    By check88 in forum Technical Discussion
    Last Post: 01-07-2002, 08:43 PM
