Results 1 to 8 of 8
Thread: Mercury LU on Yamaha
11-16-2022, 04:26 PM #15000 RPM
- Aug 2010
- Jacksonville, FL
- 144
What is done to put a Mercury lower unit on a Yamaha? Do they cut the mid and weld a Mercury bottom half onto it?
1986 Baker 18 Mod VP, Yamaha 175
2001 Crest Pontoon, 150 Opti
1968 Sears 14' aluminum, Merc 110
11-16-2022, 04:40 PM #2
Simply remove the Yamaha Mid section and Power head and swap on Merc replacement units . IDK but best of luck I am sure someone here will be able to point ya in the right direction.
22R
11-16-2022, 05:09 PM #3Team Member
- Lake Coochiching, Ontario
- 7,710
- 269
- 472
- 1543
- 6 Post(s)
I'd start by investigating the Hydrotech stuff before swapping to a Merc gearcase Yamaha Gearcase (hydrotecmarine.com)
11-17-2022, 08:39 AM #4
with what they can do now with the yamaha gear case i dont see a reason for the swap. hydrotec offers a fat shaft kit, a nose cone and skeg re-work, a billet carrier and even 1.62 gears..
1998 charger stv. 225 promax. -sold-
1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
11-17-2022, 10:21 AM #5
11-17-2022, 10:37 AM #6
Never done it to a yamaha but have on several omc projects... I have adapted 2.5 and 3.0 sportmasters to both v6 and v8 omc mids, make an adapter plate from a piece of 1/2 to 5/8 aluminum plate depending if you have to counterbore holes or not. Center on the driveshaft and drill both patterns, making the shift work is another story can be done many ways. Nose cones and epoxy work great in freshwater not so much in the salt.
David - WI, rgsauger liked this post
11-18-2022, 06:59 AM #7
the sporty case itself has better aerodynamics then the yamaha for sure. the water intakes on the yamaha case needs work to make it run high enough to be efficient. the ones done by hydrotec look alot more like a sporty when finished.
they seem to hold up pretty well around here even with the nizpro s/c upgrade done. 1,62 gears are clearly a merc inspired idea but thats fine, at least now you have options
with all this available the sporty conversion seems alot of work imo.1998 charger stv. 225 promax. -sold-
11-18-2022, 10:24 AM #85000 RPM
- Aug 2010
- Jacksonville, FL
- 144
It seems like Hydro Tec's upgrades are focused on the Yamaha HP gearcase that was used on the HPDI's. My "new" motor is a 3.1 with the stock gearcase. It's still worth asking them what's available. Thanks for the input!
Mercury 200 or Yamaha 200
By Apex2007 in forum Technical DiscussionReplies: 4Last Post: 08-15-2021, 10:15 AM -
Looking for a 115 to 125 mercury or a 115 to 130 Yamaha
By Hot Rod in forum Outboard EnginesReplies: 0Last Post: 04-24-2017, 02:24 PM -
Mercury vs. Yamaha
By Bloodfist in forum Technical DiscussionReplies: 18Last Post: 09-18-2010, 06:02 PM -
yamaha vs mercury
By bigbluechevy454 in forum Technical DiscussionReplies: 10Last Post: 07-19-2009, 09:41 PM -
Yamaha vs Mercury?!
By Marauder in forum Technical DiscussionReplies: 8Last Post: 11-20-2002, 11:07 AM
