Results 1 to 7 of 7
Thread: Big ear prop locking tab
11-16-2022, 10:29 AM #1
11-16-2022, 10:41 AM #2
They didn't provide much "notch" for the standard sun tab to go into. Lots of meat there to grind / file your notch's a little deeper, with a sharp inner corner.
No worries then about the tab slipping out of the recess ..
11-16-2022, 10:46 AM #3
Hmmm I have one that came with one of my streams that I thought was simply a smaller tab version but maybe it was cut too? Hard to say. Works ok, not great just ok. Wish Merc did like OMC and used a pin instead of these awkward finger biting tabbed washers. I've thought about drilling and pinning but so far so good, havent lost any props. I keep the nyloc nut fresh though
VkingMike liked this post
11-16-2022, 11:34 AM #4
990344 tab washer mercury - or just get a kit https://www.westmarine.com/mercury-m...661743.htmlyou can reuse the locking tab washer over and over. They make thick ones, and thin ones. I get the thin as swap props so much. Also, I have never had one spin off. Even running a SRX that doesn't have the locking castle thing on the prop and you need to cut the nut in half, it stays on with the nylock plenty good. Now if you were going to put a prop on and leave it for the next 10 years you may want to check it every so often!
here is the cheapest I found. And I use these all year, multiple years actually and I take my props off every time I go out and often multiple times a day if testing.
https://propridemarine.com/mercury-t...-v4-v6-990344/1973 Viper - sold
1978 Viking - sold
1995 XB02
11-16-2022, 11:40 AM #5
11-16-2022, 01:33 PM #6
11-16-2022, 02:46 PM #7
Non-Locking Shifter?
By JohnR in forum Props, Setup, and RiggingReplies: 5Last Post: 05-22-2011, 07:48 AM -
Locking down the flywheel
By Lou Gibbs in forum Technical DiscussionReplies: 9Last Post: 01-21-2006, 12:22 PM
